Old 06-10-2011, 01:15 PM
Stratoblaster Stratoblaster is offline
Default MBox 3 Pro and Monitors making s buzzing sound, what are the best cables?
I have an Avid Mbox Pro with a set of Mackie MR8 powered monitors hooked up to it, and then ProTools runs, I get a buzzing sound from my monitors. Right now I am using Planet Waves 1/4 TS to 1/4 TS speaker cables, I know I need balanced cables. Which cables are the best to hook up the monitors to the MBox without getting the buzzing sound? 1/4 TRS to 1/4 TRS, XLR to 1/4 TS, XLR to 1/4 TRS? I need to know the best cables to use, as the buzzing sound is driving me nuts!
Old 06-10-2011, 01:56 PM
Cali Reign Cali Reign is offline
Default Re: MBox 3 Pro and Monitors making s buzzing sound, what are the best cables?
I have the same problem with my KRK Rokit powered 5's & MBox 2 Mini...I took my stuff back to Guitar Center and they told me it's a dirty electricity problem..which to me,doesnt make sense because it only starts once Pro Tools loads..Multiple people I know have the same problem..I don't know a solution for it,as I'm looking for one too..
Old 06-12-2011, 08:44 AM
ejburns ejburns is offline
I had this same problem. I have the Mbox 2 Mini and KRK Rokit 5 G2's. When I first hooked up my monitors I used 1/4" TS cables and I had this high frequency static coming through the monitors. It was really unusable. A friend of mine gave me 2 1/4" TRS cables and it took care of the problem. I would get some TRS balanced cables and try that.
Old 06-12-2011, 10:48 AM
The buzz (for Stratoblaster)is due to the speaker cables. They are not shielded at all. Get a pair of TRS to XLR(or whatever the balanced inputs are on the Mackies). Speaker cables ar for connecting an amplifier to unpowered speakers(totally different type of signal). For Cali, it could be a poorly shielded USB cable. It could be dirty power(so see if the GC will lend you a power conditioner to prove if they are correct). The Mini is a bit trickier as you have unbalanced outputs(unbalanced signals are inherently susceptible to noise so keep those cables as short as possible). It could even be another piece of equipment nearby inducing noise(an air conditioner on the same circuit?). You might also try moving the Mbox to the other side of the computer. If its a laptop computer, try unplugging the power supply(run on battery power) to see if that helps(it often does).
Old 06-17-2011, 07:07 AM
benherron.rrr benherron.rrr is offline
Do you have a jack cable inserted into one of the inputs?
I used to get a buzzing through the monitors (KRK RP6's) when pro tools started up. I noticed the noise was coming from the Jack cable plugged into one of the inputs even when nothing was record enabled or anything. I pressed the Front-Rear button on the input and the buzz went away, and when I want to record I switch it again. It only comes from the jack when it isn't plugged into anything
Old 06-20-2011, 01:28 PM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Wink Re: MBox 3 Pro and Monitors making s buzzing sound, what are the best cables?
I Have KRK V88 Monitors, With MBOX2 and DIGI002R, with TRS Stereo Cable to XLR, and I don't have any Buzz noise. I made the Cable with Gotham Cable and Nutrick Connectors and Everything It's Ok since 4 or 5 Years.
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Help with Mbox mini buzzing and sound board danielmak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-12-2011 12:19 AM
Problems connecting Keyboard to Mbox 2 Pro via Instrument cables & getting sound mexablcknesekid MIDI 18 11-30-2010 04:23 AM
Mbox 2 mini makes a small buzzing sound. d3drocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-13-2009 10:11 PM
my digi 001 is buzzing through my monitors broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-02-2006 06:37 PM
Buzzing monitors? NoRush 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-16-2005 08:22 AM
