Old 12-07-2010, 01:15 AM
renbak renbak is offline
Default "Next start/end"- shortcut stopped working...?
Suddenly my "Previous start/end" and "Next start/end"-shortcuts have stopped working. Does anyone have any experience with that? It is nudging a couple of frames forward instead of moving to the next clip as it always has done before. Does anyone know if there is a setting where I can change this?
(PT HD 2, v 8, mac os x 10.6.2)
Old 12-07-2010, 01:35 AM
Stig Eliassen's Avatar
Default Re: "Next start/end"- shortcut stopped working...?
If something suddenly goes out of whack without you changing something, I suspect that the PT preferences need to be trashed and rebuilt. Although, I'm not sure which shortcuts you're talking about?
Old 12-07-2010, 01:37 AM
It is "L" and "Æ" on a norwegian keyboard (så du var norsk
Old 12-07-2010, 01:50 AM
midnightrambler midnightrambler is offline
You've turned Tab To Transient on by mistake. Hit alt-apple-tab to turn it off.
Old 12-07-2010, 01:54 AM
Ah, I see. Seems to be equivalent to Tab and Shift-Tab, yes?
Old 12-07-2010, 01:55 AM
Perfect! Thank you midnightrambler
Old 12-07-2010, 01:59 AM
Excactly
FastTrack Ultra 8R stopped working - have tried "everything"! trumling Pro Tools M-Powered (Mac) 2 03-15-2015 10:18 AM
Difference between "Go to Song Start" and "Return to start of session" shortcut pericoloso Pro Tools 10 2 09-22-2013 12:44 AM
"Pro Tools application has stopped working" Sandra report inside... JLiRD808 Windows 2 09-15-2012 08:27 AM
"Pro Tools Application Has Stopped Working"... shanex100 Windows 0 03-08-2011 02:33 PM
Transfuser stopped working: "set the correct path on set up page" dannielexists Virtual Instruments 2 09-16-2010 05:37 PM
