Old 02-17-2009, 08:52 AM
mgphoto mgphoto is offline
Default Drives and folders
I've done a search but have not been able to find the full answer to what to do to set up my drives and directories. I'm new to PT so thanks for any help.
My system has 4 hard drives running on XP Pro. The first drive is running system OS and PT8. The second drive is setup for audio only. I am about to install other software such as BFD/Drumagog/Reason and other plugins like Massenberg EQ. Do I install these software/plugins on the third drive or do they go on the first drive with the OS and PT?
I'd like to keep my system as clean and functional as possible.
Lost in the mix.
Old 02-17-2009, 09:21 AM
Fullsound Recording Fullsound Recording is offline
Default Re: Drives and folders
http://duc.digidesign.com/showthread.php?t=200069
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
Old 02-17-2009, 06:02 PM
Yes, I've previously read that. However, it does not address my question.
I would think this is a pretty simple question, no one to answer?
Lost in the mix.
Old 02-18-2009, 11:01 AM
KingFish KingFish is offline
You need to install Plugins, and "Applications" on your System / OS drive, with Pro-Tools
If any of those Plugins, or software, allow you to install "Sound files, Samples, or Libraries" on a location other then the OS drive, you can use another location.
I generally use a 3 drive setup.
- Drive 1 - OS and all applications
- Drive 2 - Sample Libraries, IR's, Loop Collections, Patches, etc...
- Drive 3 - Pro-Tools Sessions
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Drives and folders not showing in workspace window MLJUBB Pro Tools Express on Windows 1 06-04-2012 02:52 PM
Organizing folders; files saved to different drives; backing things up better ... quaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2010 09:05 PM
folders are being saved across drives John the Baptist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-24-2009 07:34 AM
anyway to avoid the creation of folders by digi on all my drives? Logic Pro Pro Tools M-Powered (Mac) 32 01-01-2009 02:07 PM
Limiting Digi Database Folders to specific drives? globaleric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-27-2006 12:30 PM
