Old 12-30-2007, 11:38 AM
MixerGuy MixerGuy is offline
Default copy a send (w/send level intact) from 1 to 30 audio tracks?
Is there a one step (or simple) way to copy a send (with send level intact) from one audio track to 30, simultaneously?
there must be.....
i'm just being a dumb ass.
thanks!!!
Old 12-30-2007, 12:29 PM
Rammelt Rammelt is offline
Default Re: copy a send (w/send level intact) from 1 to 30 audio tra
The easy and probably only way is simply to hold Alt and drag from your source Track to the one(s) you wish to copy it to.
The pan fader will also be copied.
Best Regards,
John
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 12-30-2007, 01:48 PM
Steve MacMillan Steve MacMillan is offline
Default Re: copy a send (w/send level intact) from 1 to 30 audio tracks?
I don't think there is a proper way to do it, and I think there ought to be. If you don't want to option drag from one fader to the next, you could highlight all of the faders and group them. Hold down shift-option and create a send on the next open track, if they are all highlighted a send will be created across all highlighted tracks. Then if your group attributes have the send number checked, you could reset all the sends by shift-option-clicking the send level and then when you set any one send the others will follow. Easier than it sounds. Too bad they have to be reset in order to move together. This is because grouped sends can move with relative offsets.
STeve
macmandigital.com
Old 12-30-2007, 03:20 PM
I don't think there is a proper way to do it, and I think there ought to be. If you don't want to option drag from one fader to the next, you could highlight all of the faders and group them. Hold down shift-option and create a send on the next open track, if they are all highlighted a send will be created across all highlighted tracks. Then if your group attributes are have the send number checked, you could reset all the sends by option-clicking the send level and then when you set any one send the others will follow. Easier than it sounds. Too bad they have to be reset in order to move together. This is because grouped sends can move with relative offsets.
STeve
thanks for the tips, Steve
yeah - if YOU don't know about it - then it don't exist!
i'll check out your tips - thanks!
Copy fader level/pan to send? sodium glow Pro Tools TDM Systems (Mac) 9 09-27-2017 03:13 PM
7.3.1 Send level meter just mirrors track level bashville Pro Tools TDM Systems (Mac) 11 01-16-2007 08:19 PM
Copy to Send in 6.9? Fiend138 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-04-2005 02:43 AM
Copy To Send JBRecording 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-12-2005 12:13 PM
channel level mirrored in send level meter daveh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2001 01:32 AM
