NI errors
Hi
I just bought the Komplete6 bundl of native instruments and instale dit yesterday. So today I wanted to work with it but i have these strange errors, mostly 0x00000 can't find program like. Sometimes I can just load teh plugin and after a little while I get thse error or on teh moment when I want more then 2 plugins. Or PT chrashes (BTW i'm using PTMP8.0.3 and bought my pc last year running XPsp3 Quadcore 4gb ram) and on the CPU eter it denst reach the max. And I'm getting a little pissed at this moment because finnaly i've got the stuff to work with and now I get these errors and stuff. I het to restart my pc dozens of times GRRRRR. Anybody else wih this problem or who knows how to solve it? great ferry |
Re: NI errors
To be A little more specific, I just loaded FM8 and Guitar rig4Now I want to load Battery3 i get the next message:
Acces Violation ocured, unable to read location: 0x00000000 at address: 0x00000000 in module : ProTools M-powered.exe |
Re: NI errors
Throw in a Sandra report for good measure, although I seriously doubt the problem exists there.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Re: NI errors
A WHat Report?
Re: NI errors
another addition, just discoverd I can't add any extra softsynth not even boom or xpand
Re: NI errors
(NI) Native Instruments? I really do not know about the NI software you have or your set up but I do know that I have the Free Kore Player and Kontakt Player and both are unstable in any Pro Tools session I have ever tried to use them in so I just dont use them. I do use them stand alone when I want to jam but I never load them into a Pro Tools session. Just My Two Cents.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Re: NI errors
It are the fullversions of Kontakt4 FM8 Battery3 Massive Reaktor5 and absynth5 |
Re: NI errors
Re: NI errors
Have you contacted NI about this at all? If so, I can talk to them about the case and see if we can figure out what's going wrong. Access violations usually occur due to having old/incompatible or unauthorized plug-ins installed. The error may occur with other plug-ins, other than the old/incompatible/unauthorized ones - I would make sure you have ONLY compatible ones installed. If you can zip up your Log Files folder (inside your Pro Tools folder) and email it to me at: vi [at] digidesign [dot] com, I'll take a look at it and see if anything there gives us a clue as to what may be going wrong. |
Re: NI errors
HI
I Have al the recent versions. I Updated them right after I installed everything with the service center. I Haven't contacted NI about is because it didn't appeared with other daw's. I'm going to send you my logfiles by e-mail Greatings ferry |
many errors- fatal errors and 9060 error. Sandra report inlcuded.. | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 09-16-2009 11:56 AM |
Creating DAE Objects/DAE Loaded!! errors errors HELP!!!!! | KasticK | Pro Tools M-Powered (Mac) | 2 | 10-20-2007 10:42 AM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
errors errors errors Please digi tech guys help me | dunkyj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-11-2005 01:19 PM |
Can converter errors cause waveform errors like .. | Booyah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-20-2004 03:43 PM |
