Old 10-23-2018, 08:29 AM
Spyderrp7 Spyderrp7 is offline
Default Audio handles on AudioSuite render get greyed out!
Hello, I have noticed something about Audio Suite
I want to audiosuite render a bunch of clips but I don't want to consolidate, so I choose in the audiosuite settings "create individual files" instead of "create continuous file". When I select "create individual files" all the options for audio handles (such as the number of seconds or the whole file) get greyed out for some plugins. But I need handles.
For example:
It works ok with plugins such as: EQ3 7-Band
But it doesn't work with plugins such as: Gain, Channel Strip
What is the issue here?
Old 10-23-2018, 08:45 AM
BScout BScout is offline
Default Re: Audio handles on AudioSuite render get greyed out!
Those other two with the greyed out are set to "entire selection" and they need to be set to "clip by clip" like the first one.
(And you can't use "multi-input mode" -- it will auto switch -- when in "clip by clip" for the channel strip. But you aren't actually using it anyway so it probably isn't a big deal)
Old 10-23-2018, 08:59 AM
You are correct!! Thank you so much!
Audiosuite w/ handles mentalsanityoff Pro Tools 9 1 04-16-2012 03:35 PM
Next PT comes with AudioSuite handles!!! nedd Post - Surround - Video 34 03-05-2012 06:21 PM
audiosuite handles? Matt Chan Post - Surround - Video 75 10-09-2011 02:01 AM
Render audiosuite without expanding handles? SirLexelot Post - Surround - Video 9 07-04-2005 01:41 AM
Audiosuite handles please BlueDog Pro Tools TDM Systems (Mac) 11 06-15-2004 06:37 PM
