#21
Re: Waves Update Plan - WUP - What’s the point?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#22
10 years ago we had V5 so excuse me if I straighten some corners but it would have given them 2 years per version if they released V10 now.
How log has V9 been around, anyone..? I can tell you. 6 years and counting...
#23
They work as they should but I would like to see v.10 before my WUP expires, right now I only have to pay $14 to be fully back on WUP.
#24
And what has been updated since then that has warranted updating WUP? Nothing.
Lots of new plugins. They've upped the cap for global WUP to $300 a while back too. I think I am missing out on a couple of plugins added to Gold that I probably wouldn't use since I haven't had a need for them to this point. I have spent way more on their $29 deals than I ever have for WUP. 27 of my 38 plugins/bundles are out of date when it comes to WUP. The only ones that are active are purchases in the past year. Abbey Road show up individually but those update when they release a new plugin to the bundle, which they haven't since March 29 of last year (just lapsed). That said I am considering their SoundGrid Impact server since it's the same price as the UAD box (but I am not on the UAD train). The main reason is because Abbey Road Plates is a CPU hog. |
#25
They were less dependent on WUP when they found out Walmart’s Low Price Strategy brings in tons of cash
#26
Even the DBX, although good, i use the softube/NI one with it's adjustable high pass which is unique in all 160 emus. But waves did pretty good on that too. They really tarnished my opinion and their reputation with their absolutely awful CLA stuff, the comps in omni channel also awful, h-comp awful, the C1 "workhorse" that *sounds* awful, heck even old ren comp is better than a lot of them (again IMO.. have to stress that!). Anyway sorry to go off track.. personally i don't find abbey works in a mix and to be honest i just don't like the sound of it overall. I advise you to try a UAD satellite, they have recently almost all halved in price..they are fanless.. and they simply work.. no hoops to jump through to install or auth in any way... I'm trying to find out how much latency waves plugins add on top of their normal latency when used via impact, but i haven't been able to.. if you find out do let us know... The curiosity is there, simply to offload all processing from my cpu and save it all for VI's, and between impact and UAD i could almost accomplish that (some alliance plugins can be used on impact as well, even a couple sonnox i think).. I love Alliance stuff in general with a few rare exceptions so i'll keep my eye on impact for reviews and latency. Anyway, my post was sort of to convince you to go UAD.. I am being honest ok.. I have ripped UAD a new butt hole many times over their BS claims for zero latency on apollo, and other things, but, i have seriously, and i mean seriously done head to head with every plugin they produce with all native solutions where there is a direct comparison, and in the case where there are waves versions, sound wise, the UAD won every single time, and not by a little. My goodness, waves first did the 1073, then re issued a high cpu version where they used their all new latest modelling techniques for, with the scheps 73, and the UAD 73 mkII absolutely annihilates it (just for one example). .Even crappy youtube audio quality can show you this if you don't believe me. So if you want top plugins, re consider UAD since a quad is the same price as impact. It will not give you impact instance counts but it is still very useful to have, believe me. The only situation where i preferred a native algorithmic (i.e non nebula convolution) plugin to a UAD version was the IK precision compressor vs the UAD 33609. The UAD is a bit, "tinnier" for want of a better word. Another example vs waves. the LA3A.. UAD LA3A is an old, non MK2 plugin, with the tiniest gui that can barely be seen on any modern screen.. Sound wise, it absolutely crushes the waves CLA3A in every way. It just SOUNDS fantastic.. I use it non stop on every project. And it's light as a feather on DSP..10 stereo instances uses about 20% of a quad. PS dsp load lock on UAD is very useful and it really works.. you can actually stop any dsp being used for disabled sections of plugins.. for example if you just want to use the pre amp of the 1073 and not the EQ, or a strip and not use say the comp in it, or the expander.. It can help really maximise chip usage to the max. Hope that helps.. i know uad backwards now, all the pitfalls, cons, AND pros, and have either demoed or bought and used every single plugin on offer extensively, so if you ever need any help please feel free to PM. Cheers PS waves comps.. almost every single one of them suffers from rest and pop syndrome.. i.e gain reduction has finished cause playback is stopped or a blank section of audio.. when first encountering audio again the comp will POP and let a loud first transient through before it begins normal compression. there are plenty of zero latency native compressors without look ahead, that do NOT suffer from this. Some MCDSP and 95% of waves really suffer from this. Just another example of subpar coding.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#27
WUP stands for Wildly Unreal Pricegouge.
Ok I took a little poetic liberty but u see what I did? Sent from my iPhone using Tapatalk
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
#28
They have been good for several years now, but most of my stuff is out of WUP Probably stay that way too, damm the torpedoes
#29
Everybody raves about the UAD stuff but I am not crazy about having to buy hardware just to run their plugs. I really like the Slate stuff but prefer the Waves SSL channels. I love the VTM and VCC and just picked up some of Slate's other stuff along the way. Each year when I do my taxes I get alarmed at how much I spend every year on plugins (like last week for instance). Even though that number is going down it is still more than I should be spending. UAD had a deal earlier this year that I could/should have jumped on because there were a lot of extras thrown in but I am already deep in Waves, Slate and Plugin Alliance that it's hard to justify adding yet another company's plugins to that. I do not have any McDSP other than Futzbox, have a handful of SoundToys and MH and most of Massey's etc but I am trying to consciously reduce what I use and buy. Hi, my name is Jim and I have a plugin problem... |
#30
UAD's reissued SSL channel strip and bus compressor is to die for. I mean literally unbelievable.. like you are using an SSL desk... I can't live without them. Good bye duende, good bye waves. Was doing a shoot out the other day on a full mix.. used the glue, my previous fave, PSP bus comp, vertigo VSC2, duende, IK SSL, waves SSL bus comp, UAD. It just obliterated all of them.. The presence and "glue" added, zero peak volume change, was amazing. I honestly always thought it couldn't get better than the glue till i heard that. Slate's bus comp is not even close in this regard (i'm a huge fan of the slate distressor, in fact it was good enough to save me money buying the UAD one.. i also use VCC religiously, so, we have similar taste)
Re: Your Waves Update Plan is About to Expire | Touchwood Studios | Pro Tools TDM Systems (Mac) | 63 | 03-01-2017 01:01 PM |
Waves Update Plan could be a reference for PT Update Plan | jacko | Licensing & Accounts | 0 | 12-06-2015 03:19 AM |
waves sell out,update plan | tobias bluth | Pro Tools 9 | 0 | 11-23-2011 05:00 PM |
Changes to Waves Update Plan | gives | Pro Tools TDM Systems (Mac) | 0 | 03-29-2007 04:09 PM |
Waves update plan recommended???? | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-20-2005 11:14 AM |
