Old 08-04-2013, 12:00 PM
Ewan T Ewan T is offline
Default "The track could not be record enabled..."
Hi
I'm running Pro Tools 10 with an MBox mini plugged into a 2.7 ghz retina MBP with 16 GB ram (running OSX 10.8.4).
When I start a session and create a mono track then go to record enable it I get this message:
"The track could not be record enabled because it doesn't have both an active input and output assigned"
I'll say up front, I'm not a pro user I'm a voice over who occasionally uses this software. I've had an mbox of one kind or another for about 10 years and have always managed to make it work (eventually). But I've been tinkering with this for ages and don't seem to be able to fix it.
FYI the Mbox has one channel into it and there's a Sennheiser shot gun mike plugged into it.
Any help greatly appreciated.
Thanks
Ewan
Old 08-04-2013, 12:08 PM
Default Re: "The track could not be record enabled..."
Is the Mbox the selected device under Setup>Audio Engine? After that, try selecting the input and output on the track you wish to record to.
Old 08-04-2013, 02:31 PM
Hi. Thanks for the reply.
I think I've done as you suggested. However, when I click the "input" button on the track and the drop down appears listing "interface" and "bus" - when I go to interface there's nothing listed for me to select.
There should be an option, shouldn't there? There's plenty on the "bus" drop down - but I don't think that's a what I need.
Ewan
Old 08-04-2013, 03:12 PM
Ah. OK. I seem to have figured it out.
Thanks for the help!
Old 08-04-2013, 07:06 PM
zedhed's Avatar
zedhed zedhed is offline
Prolly just needed to 'Default' I/O no?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack spankyq Pro Tools 10 8 04-20-2015 08:19 AM
Error message when i try to record. "track could not be record-enables...." znera143 macOS 3 01-20-2012 06:17 PM
Horrible Delay and Reverb on "record enabled" in PTLE 8.0 jbandhisguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2009 10:32 AM
"Track" as a synonym for "record" John Link General Discussion 2 08-19-2002 11:54 PM
"auditioning" record-enabled tracks markert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2001 10:12 PM
