Old 07-21-2011, 07:55 AM
brickroadstudio brickroadstudio is offline
Default Pop at the end of bounced files
I have posted about this and no one seems to be able to help-
Sometimes when I bounce, I get a "pop" at the very end when its done- All the faders go up for a split second.
The problem is, this POP gets onto the final mixed down .wav file.
Doesn't always happen, but often enough to be a huge pain in the ass.
Why does this happen and how do I get it to stop?
Thank You
Old 07-21-2011, 09:37 AM
DigiTechSupt's Avatar
Default Re: Pop at the end of bounced files
Are you using automation on the Master Fader?
Avid Audio Tech Support
Support FAQ
Old 07-21-2011, 01:07 PM
Yes, to make a fade out-- but at the end the line is at the bottom, its not snapping up to the normal level at the end of the highlighted bounce feature.
So is this a known bug then? I used to never have this issue, even with automation on the master fader...
Old 07-23-2011, 10:40 AM
So?????
Old 07-23-2011, 01:55 PM
This is a known issue and is logged for a fix. The workaround seems to be making sure your automation ends before the region end.
Support FAQ
Old 07-24-2011, 11:23 PM
The final automation point is at the end of the fadeout. I usually highlight a second past that-- the pop sound is at the end of the bounce upon completion (I also see all the fader meters pop to the red.) not at the automation point...
SO I am not sure what you are suggesting.
Old 07-25-2011, 04:53 AM
psmworld's Avatar
psmworld psmworld is offline
pops also occur when starting or stopping playback!!!
it´s annoying when you´re editing. hundreds of starts and stops and most of the time getting loud pops...
Selling:
Old 07-25-2011, 07:13 AM
midnightrambler midnightrambler is offline
I'm guessing that the pop is from when the master fader jumps back to 0dB, a split second before the files have finished being written. Have you tried writing the master fader level at the beginning of the track to -infinity, then having it at 0dB just before the track comes in? So the master fader doesn't jump back up when the track stops. If you see what I mean. It's not the most elegant of workarounds admittedly, but it might just work.
Old 07-25-2011, 12:17 PM
It doesnt pop back up. I have it fade to the bottom and then the line stays at the bottom...
Old 07-25-2011, 12:54 PM
Jon_Atkinson Jon_Atkinson is offline
Without wishing to seem as if I'm trying to paper over a clearly irritating bug, I actually never use Bounce To Disk....
My workflow is always to record via an AUX back into the session (which might get around this bug), as I find it works for me much better for keeping track of my mixes....
I mostly create music for TV and film, so I often have a LOT of cues (sometimes a couple of hundred on a project...!)... Keeping the mixes within the sessions really helps me keep track of them.... Also, sometimes I have to punch in a section on a mix... It's much easier to do this using this workflow.
Also, it means I can easily export mp3 files for the director to approve, and also I find it easier to fade tracks (and also join cues together)...
I totally get that the bug needs fixing, but if this method might get around your issues, maybe try it as an alternative?
Volume too low on bounced waw files digidane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 05:49 AM
Bounced files end gets cut off breakie Pro Tools TDM Systems (Mac) 8 05-25-2005 01:26 PM
Recorded bounced files have a pop at end...help ScottFclef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-12-2003 04:18 PM
Bounced files shameeta General Discussion 4 11-09-2003 07:36 PM
burning bounced files to cd?? dave813 Digidesign Hardware & Software 2 12-20-2002 07:51 AM
