Bug with automatically created 5.1 Bussss
I create a new 5.1 Aux. It by default has no input and the default output. I then route a track to it via the I/O menu of that track and NOT by creating a Bus in the I/O Setup menu. Pro Tools creates the 5.1 Bus and its sub paths automatically. But the channel order of the Quad sub path is wrong.
This is Pro Tools 2020.5. I've seen this in previous version too. Can anyone confirm this? |
Re: Bug with automatically created 5.1 Bussss
I can confirm.
MacBook Pro 2018 i9 10.14.6 PT Ultimate 2020.5 HD Native + Omni I had created a support case about this late last year. After a LOT of back and forth with support, I finally got them to admit that there was a problem. They said that they would address it, but I'm sure it isn't super high on the priority list. I would encourage you to create a new support case, as the more people who do so, the more likely it will be escalated to a higher priority. EDIT: Just tried a test, instead of being fixed, it seems to have gotten worse and more scrambled. Attached is a screenshot of me trying this just now. Once creating via the route to track or new track option in the drop down menu (both had the same results) and one created in the I/O Setup window with the Auto-create sub paths option ticked. There are a couple threads about this: http://duc.avid.com/showthread.php?t=405337&page=2 http://duc.avid.com/showthread.php?t=407415
Scott Gatteño |
Oh, that's totally messed up. I was aware that this has been a problem for several versions. So at least since 2018.12.
A colleague of mine created a support case. I did as well. |
Can't open sessions created 11.3.1 on 10.3.9 error: because created in older version | axisrecording | Pro Tools 10 | 0 | 01-30-2020 10:37 AM |
Avid deposited PT12 licenses in an automatically-created iLok account - Bad! | Onager1286 | Licensing & Accounts | 3 | 12-23-2015 06:55 PM |
Automatically Return to Zero | DirtyDingo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-09-2010 03:10 PM |
punching in and out automatically | jeradbay | General Discussion | 9 | 12-04-2009 09:04 AM |
digidesign databases created automatically | globalhiccup | Pro Tools M-Powered (Mac) | 1 | 01-05-2008 03:23 PM |
