Old 10-01-2020, 06:51 PM
Scott G Scott G is offline
Default Renaming clips in order along the time line?
I have about 1500 clips strung along the time line that I have cut up from at 3hr file. I want them labelled in order. When I use the rename feature in strip silence the numbering is int consistent. In the end I need to export them as wav files.
Any help would be appreciated
Thanks
Scott
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 10-02-2020, 06:41 AM
reichman's Avatar
reichman reichman is offline
Default Re: Renaming clips in order along the time line?
The new batch rename function will order names with left to right and top to bottom as the guiding order. Then export as usual. Good luck!
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 10-04-2020, 03:01 PM
What version do I need for the batch rename function?
Thanks
Scott
Scott
Old 10-04-2020, 03:06 PM
reichman's Avatar
I think 12.8.2:
https://www.avidblogs.com/rename-gro...-batch-rename/
It's really good. We've been needing this.
Nathaniel Reichman
Old 10-05-2020, 08:28 AM
If you haven't used this, it's worth noting that it just renames the clips in the session, it doesn't actually rename the files themselves.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 11-05-2020, 07:17 PM
citysoundman citysoundman is offline
Yes! Batch renaming using timeline order is a HUGE upgrade. There's lots of features for renaming including adding prefixes, suffixes, numbering schemes, pretty much anything you would need. And it does it instantly
Bob Kirschner
NYC-based Audio Post Mixer/Sound Designer
bobkirschner.com
HTML code is On
Renaming Clips/Files indeloon85 Pro Tools 2018 5 08-22-2018 11:54 AM
Renaming duplicated clips? lightningad1 Pro Tools 12 2 03-24-2016 05:15 AM
Auto Renaming not in order Jim Cline Pro Tools TDM Systems (Mac) 7 07-30-2002 12:57 AM
