Old 05-13-2019, 02:54 AM
MarkoTervonen1976 MarkoTervonen1976 is offline
Default No audio when toggling solo (AFL Mode) during playback (PT-251511)
Does the solo behave like this for you?? :-o
https://drive.google.com/file/d/1hf7...w?usp=drivesdk
ADMIN EDIT: Known issue, please see the 2019.5 Read Me http://avid.force.com/pkb/articles/d...5-Release-Info
Last edited by DigiTechSupt; 05-31-2019 at 10:38 AM. Reason: Threads Merged, Link Added.
Old 05-13-2019, 03:02 AM
Default Re: Pto Tools 2019.5 solo/mute bug?
Useless post deleted, sorry I had not really looked closely enough at the video.
Old 05-13-2019, 03:15 AM
jchan jchan is offline
To me it seems like a bug.
I can reproduce by selecting Solo-mode "AFL"
Works one time, then mute.
I also discovered that with 2019.5 I cannot solo-safe any channel.
Edit: I guess you can't solo-safe in AFL mode.
Old 05-13-2019, 03:43 AM
Oh yes, it's a bug. Seemingly only when using AFL Mode. Sorry, ignore my useless earlier post.
To reproduce:
In 2019.5 Create a new empty session.
Create two audio tracks, drag and drop some audio content on them. Stereo, mono, your choice.
You can be in Latch or X-OR mode both show the audio not working.
Hit play. Now soloing one and then the other track while the transport is running.
In solo AFL mode you don't hear any audio after the second time you solo. Stopping and starting the transport gets you back audio. SIP and PFL modes do not show this problem.
Old 05-13-2019, 04:28 AM
Drew Mazurek's Avatar
No need since it uses a "separate" Solo Buss unlike SIP which uses the "stereo buss"
www.drewmazurek.com
Old 05-13-2019, 04:34 AM
innenhofstudios innenhofstudios is offline
works fine here.
does this also happen on a track with no plugins ? Maybe a plugin inserted which conflicts ?
www.innenhofstudios.at
Old 05-13-2019, 04:31 PM
Originally Posted by innenhofstudios View Post
works fine here.
It is not clear which post or part of it you are replying to. If the stuff shown in the first post... are you using AFL mode, the problem only happened in AFL mode. It happens with no plugins instantiated, as simple to reproduce as my previous post..
Old 05-14-2019, 10:22 PM
Default Re: Pro Tools 2019.5 solo/mute bug?
Oh damn, we all failed to read the release notes carefully.
This is already documented as a know issue in the 2019.5 release notes. So Avid is well aware of the issue, thanks jeffro for pointing that out.
From the release notes...
"No audio when toggling solo (AFL Mode) during playback. (PT-251511)
Audio returns when the track's volume fader is touched or if the track hits a an automation volume change."
Old 05-19-2019, 08:13 AM
clancychris clancychris is offline
Default Solo In Place glitch
Anyone else experiencing issues with Solo In Place (SIP) mode?
I have to solo a track, stop playback and then hit play again to hear the soloed track. If I just hit solo on a track it's silent. Works fine with other solo modes.
Old 05-19-2019, 09:08 AM
Default Re: Solo In Place glitch
Solo AFL mode bug is discussed on DUC already, and a known issue in the 2019.5 release notes.
But you said SIP not AFL mode... see if it’s the same issue as described here or in the release notes.
http://duc.avid.com/showthread.php?t=404671
Toggling 11R rig out in ASIO mode - solved? adamqlw Eleven Rack 3 10-06-2011 12:18 PM
AFL Solo mode and solo trim brenttrf VENUE Live Sound Systems 2 09-18-2010 12:44 AM
Toggling audio between itunes and pro tools session/DIGI 002 freedomrock69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2009 01:15 PM
toggling input on audio track causes pop: PT8 Erik Zobler Pro Tools TDM Systems (Mac) 1 12-31-2008 12:53 AM
"...not an audio playback volume" error in bounce mode blankpro Pro Tools TDM Systems (Mac) 1 12-13-2007 11:26 AM
