Old 11-27-2019, 03:12 AM
@tention @tention is offline
Default 2019.10 and AAF Import
Hi forum,
is it only me or is 2019.10 suddenly having problems linking files from AAF?
When I import the same AAF in 2019.6 it just immediately finds all files while in 2019.10 I get a missing files dialog although all files are in the same directory on the drive.
I have seen this behavior on two different installations.
SOUND!
Old 11-27-2019, 06:00 AM
BScout BScout is offline
Default Re: 2019.10 and AAF Import
I have opened 30-40 AAFs since 2019.10 came out. They came from 3 different editorial rooms (one running Media Composer, one Premiere, and one I don't know about.)
Zero issues. Works perfectly.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 11-28-2019, 01:38 AM
seanmccoy seanmccoy is offline
Same here. Several AAF's opened in 2019.10 with no problems. And liking the feature to ignore clips not on the timeline.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2019.12, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.8, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU LP32, Pro Tools 2019.10
Old 11-28-2019, 03:13 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Originally Posted by @tention View Post
Hi forum,
Ive run into this, as the search was not drilling deep into the file hierarchy.
Ive had to actually point to the correct folder.
I have no explanation.
IMDB
Old 11-29-2019, 12:35 AM
thierryd thierryd is offline
This I’ve seen as well on various versions of PT through the years, recently on 2019.6
I’m not upgrading to 2019.10 due to too much issues I read about on DUC.
Greetings,
Thierry
http://www.a-sound.com/
Old 12-03-2019, 01:17 PM
ZolonDk ZolonDk is offline
I have this problem on 2019.10. But only when AAF is linking to mxf audio files. Pro Tools won't recognize mxf files as audio. Even when I try to import mxf file from old session, Pro Tools won't read. Even though the session they belong to plays just fine. It's very strange.
I opened a support case. No solution yet.
Downgrading to 2019.6 made it possible for me to work with mxf audio files again.
Old 12-07-2019, 10:57 AM
Ale Ale is offline
My solution I found that’s worked every time when protools could not open Aaf or did not find audiofiles or could not relink even if the files are there or......
Import aaf with nuendo and resave aaf with nuendo
You can do this with the demo
Even if you do not have skills on nuendo like me its easy to do and very fast
Just resave with linked to audiofiles
It my case it worked every time this year.
Ale
3x PT HD Ultimate 2019.10 6/12-Core Westmere/ 48 GB / OS 10.12.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2019.6 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002
www.tonstudio-gress.de
www.facebook.com/TonstudioGress
HTML code is On
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 09:12 AM
Import Session Data or OMF Import creating regions of white noise Rob S Pro Tools 2019 0 09-23-2019 02:43 PM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 09:30 AM
Cannot import videofile on Pro Tools 2019.5 matiasca Pro Tools 2019 5 06-25-2019 10:36 AM
