Old 11-26-2010, 06:10 AM
epu epu is offline
Default 1394 Light Blinks In Win7/64, But Not XP?
On another P5K build. The 003 works FINE when using XP and 8.0.1. I can successfully install 8.0.4 on Win 7/64, but the program never finishes loading and the 003 displays a blinking green light (1394). The computer recognizes the 003 in DEVICES. What may be the problem. I'll post a Sandra report if requested (bare in mind that it does work w/no problem in XP. If I image XP on my drive using ACRONIS TRUE IMAGE, it works great, when I image Win 7/64, not so much).
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 11-26-2010, 08:03 AM
Default Re: 1394 Light Blinks In Win7/64, But Not XP?
Try using the Legacy firewire driver(in Win7 x64).
Old 11-26-2010, 11:34 AM
epu epu is offline
Hey Albee. This has helped tremendously. PT loads and I have all of my plugs installed, BUT it takes four years to load! (Forever to load the program itself, and then forever to load the session). Clearly this isn't normal. Is IE8 still a problem on Win 7/64?
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 11-26-2010, 11:56 AM
4 years.....I told you a million times not to exaggerate. I can't really comment re. IE8 as I removed it and run Firefox on my system(but I thought it was an XP issue). What plugins are you running(other than stock stuff). My Waves Mercury Bundle does take several minutes to load. Also, load times are slow the first time(and the first time after trashing prefs as the software is scanning all the plugins again). First thing to figure out is whether Pro Tools runs okay
Old 11-26-2010, 01:58 PM
epu epu is offline
Seriously, I've had this and slow 'saving backups' where the entire system freezes until its done saving the backup. I had the slow program load with just the stock plugs. I did then add NI Plugs (Kontakt, Battery, etc) with the same results (slow program load, slow session load, slow saving backups, freezing, etc).
Interestingly enough, any program which could utilize the 003 in standalone mode (Kontakt, etc). did not have the same issue (they load right away).
I'm not sure what was going on, but I just reverted back to 8.0.1 on XP because I didn't have time to deal with the headache.
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 11-26-2010, 08:58 PM
when you built this PC, did you install everything that was on the motherboard disk? Just wondering if you have some bloatware on your system that is dragging the performance down. You might also try setting TAM timings manually to see what happens. I would also post a Sandra report as someone may spot a hardware issue.
Old 11-27-2010, 02:49 AM
epu epu is offline
Nope, no bloatware. Did the manual RAM settings a million times over. Remember, I RUN PT PERFECTLY UNDER XP, all I did was install Win 7/64. It must be something w/Digi's drivers (on my particular system). I've read enough threads here on this subject. There's absolutely no reason why my system should run PT perfectly (as tweaked as it is) under XP and then not under Win 7 (w/all of the necessary Win 7 optimizations).
I have no extraneous plugs (just the stock ones). I get the bad performance whether I have PT installed by itself, or install my NI stuff.
I will post a Sandra report as soon as I can. Thanks so much for your help so far.
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
xp32 bit 1394 Light Blinks goes away freeze at DAE SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 04-16-2010 11:40 AM
1394 Light not WORKING!!! light not coming on at all HELLLPP Shizzle408 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-24-2009 03:42 PM
1394 led light blinks on 002 Irenaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-18-2008 08:08 AM
1394 light on my Digi 002 Rack blinks and locks up mseans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-12-2006 03:20 PM
