HDX Card is Not Recognized Any Longer.
I started a case with Avid support but wanted to share to see if anyone else had similar issues.
Our HDX Card is not recognized/appear any longer. I have tried most of the basic troubleshooting steps but still No Go. . . The only recent changes were: Updating PT to v2018-12 and Swapping two of the backup hard disks with higher capacity ones. Otherwise I’m running the exact same configuration which has been running rock solid for the last 2 years. Our System: MacPro (Trash Can) v10.13.2 PTX & HD I/O Running the latest version of PT Ultimate v12-2018 Sonnet Echo Express III-D Thunderbolt 2 chassis: with 1 HDX and 2 Tempo SSD ProPlus PCIe cards Each Tempo SSD Pro Plus PCIe card has 2 SSD Drives (total of 4 SSD Drives) The Sonnet chassis must be working fine as all the SSD drives in it mount and run just fine. Not sure if it is a driver or hardware issue. Frustrating! Anyone?
:+: Last edited by A1; 12-30-2018 at 04:08 PM. Reason: Added Details |
Re: Problems with HDX Card in Sonnet Echo Express III-D Thunderbolt 2
Hello,
Is it seen in System Report? Hugh |
Reseat the card and power cable.
If you were inside the chassis, there's a chance you've dislodged something when doing the hard drive upgrade.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I reseat the HDX card even tried different PCIE slots. . . still no go
:+: Last edited by A1; 01-04-2019 at 04:14 PM. |
Yes, definitely check the HDX Aux power cable, but also.. What version did you upgrade from? Is it possible that you have to deal with the iLok DigiLink licence issue? (DigiLink now needs a separate iLok auth, in addition to the ProTools auth group).
From PT 12.6 and onward you would need a Digilink license but any version before does not require a Digilink license.
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
Had the same problem. Support told me to uninstall the PT driver, open System Preferences/Security & Privacy. Unlock and leave open as you re-install driver. Security & Privacy was preventing a proper install. Worked. I've run into this problem with other software installs.
DigiLink license is in place. I also Re-initialized the HDX Driver. Still No Go.
The initial problem started after installing the 2TB OWC SSD's on the Tempo SSD PCIEs.
Those 2TB drives either didn't mount nor work properly, so I took them out and installed back the original 1TB SSD's. Don't know what but mounting those 2TB SSDs broke things. Perhaps the extra power they consumed caused some kind of surge which damaged the HDX card or its power cable. We've had the Sonnet Echo Express III-D TB2 with the same setup for quite a while now and all worked like a charm with very low fan noise. Now, with the exact same configuration, the fan starts to just blasts when the HDX card is in the chassis. It is very quiet (back to normal) with the other two Tempo PCIE cards when the HDX card is taken out. Re-initialized the HDX drivers Re-seat and reset the HDX card Temporarily removed the Tempo SSD PCIEs and had only the HDX card running in the chassis. Tried different PCIE slots. Despite extensive troubleshooting. . . still no go. . . Neither Mac nor DigiTest recognizes the HDX card. At this point I'm assuming that something is wrong with the HDX card itself. Unfortunately I don't have another PCIE equipped system/chassis to test it on. Still waiting for Support to respond. Anyone else with suggestions?
I have the same problem. Do you solved! Thanks Antonio
Antonio Taccone Master T Studio - Mac Book Pro Touch Bar 2017 3.1 GHz Intel Core i7 - Pro Tools Ultimate - N° 2 HDX - C 24 - Pro Tools 12 HD - N° 02 HD i/o - Focusrite Red 16 Line - N° 2 UAD Apollo 8 Black series - Neve - Focusrite - Avalon - Millennia - Summit - Bricasti - Quested - Meyer - Universal Audio - Waves, Softube, Plugin Alliance, Slate Digital, UAD, etc etc. |
Sonnet Echo Express III-D Thunderbolt 3 edition | WildHoney | Pro Tools HDX & HD Native Systems (Mac) | 4 | 11-16-2018 01:37 PM |
Sonnet Echo Express SE-II thunderbolt 2 chassis and eSATA PCIe card | John_Toolbox | Buy & Sell | 1 | 02-05-2015 08:12 AM |
PT HDX and the new SONNET 1-slot Echo Express SEL Thunderbolt 2 Expansion Chassis? | Heinz Kohlbauer | Pro Tools HDX & HD Native Systems (Mac) | 1 | 03-27-2014 10:59 AM |
Sonnet Echo Express III-R Thunderbolt PCIe Expansion Chassis | Andi R | Pro Tools HDX & HD Native Systems (Mac) | 22 | 02-05-2014 10:35 PM |
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports | Barry Johns | Pro Tools TDM Systems (Mac) | 29 | 08-11-2012 07:01 AM |
