Midi Controllers - Midi Port Assignment
MBox Pro
OS X - 10.7.3 Pro Tools - 9.0.5 MPK49 (Controller / Keys) Maschine (Controller - Percussion Pad) I'm assuming the reason I can't switch signal input from one controller to another is because of the way my midi ports are set up, is this correct? Right now I can only get signal input (from my Maschiine pad) using my MPK controller. Do I need to switch midi ports around so I can get signal input from Maschine directly into PT? More ideally, how can I get signal input from both of these controllers? My current midi port assignment is: MPK49, Port 1 MPK49, Port 2 MPK49, Port 3 Maschine Controller, Midi input port 0 Also, even when I assign the Maschine controller using the I/O assignment in the Mix window, I still cannot get signal input directly into PT (without going through the MPK). Any thoughts here? Thanks for your help! -E |
Re: Midi Controllers - Midi Port Assignment
Are you using Midi cables or USB? If Midi cables what is your audio interface?
Mac Pro 3.2GHz Quad-Core Intel Xeon "Nehalem" 16GB 1066MHz DDR3 ECC SDRAM ATI Radeon HD 5870 1GB 120GB OCZ Vertex SATA II MLC SSD 1TB Apple 7200-rpm Serial ATA 3Gb/s HD Pro Tools 8.0.4 M-Audio Fast Track Pro M-Audio Axiom Pro 61 |
Midi Predifined options in Peripherals\Midi Controllers menu | RuffinMedia | macOS | 3 | 03-04-2015 04:54 PM |
MIDI CC Assignment Table in Pro Tools | AMIEL | MIDI | 5 | 10-14-2013 12:12 AM |
MIDI Virtual Ports not showing up in MIDI Controllers (8.0.5) | emiliojazz | Pro Tools M-Powered (Mac) | 0 | 02-18-2013 12:03 PM |
Midi Controllers - Midi Port Assignment | eneezy1 | macOS | 4 | 07-30-2012 02:40 PM |
Virtual MIDI port and legacy controllers | aronnelson | Pro Tools TDM Systems (Mac) | 0 | 02-08-2010 01:47 PM |
