Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 12-22-2018, 11:59 PM
undadogz undadogz is offline
Default Muddy mix
Hello not sure if i am allowed to post this here but i have been struggling a bit with translation poor headphone quality
at the moment i am using
mac pro 12 core
3x digi 192 audio and digital outs
1x ssl sigma
1core pcie 2accel
Yamaha Hs 5
Digi control 24
Headphones i have coming aux out ssl sigma via db25 to 8 trs only using 1+2 into mackie hm 800 headphone amp then hm 800 outputs x8 to patchbay in then headphones are directly connected to the patchbay outputs is this correct setup ...it works but sounds very muddy ? i use to come me out of the control 24 aux send but same problem
very muddy ...
as for the translation from mixing monitors to car speakers sound great but i struggle with any other format very bottom heavy and mid i have adjusted the db + - to see if it helps on the monitors but still struggling i have put a little no to a example hope that is ok if not then i will delete the link ...many thanks for any advice
https://youtu.be/YS51XnhRVdY
Old 12-23-2018, 10:01 AM
Default Re: Muddy mix
The linked video sounds fine to me. So it seems its only headphones that sound muddy? That could be a few things;
1-crappy headphones(you didn't mention brand or model)
2-crappy headphone amp(never used the Mackie, but am very happy with the ART HeadAmp 6 Pro)
3-high-impedance(600 ohm) headphones driven by an amp designed for low impedance(8-32 ohm) phones
4-clipped signal feeding the headphone amp
How are you feeding the headphone amp? Does it get the main mix or are you using sends? I would use sends and this would allow you to insert a master track for the send, and insert an EQ plugin to try an compensate(this is grasping at straws because I think something else is to blame)
Old 12-23-2018, 11:56 AM
Hi thank you so much for replying ..I use to send a stereo signal from the aux sends on the control 24 to the headphone amp ..i could send diff mixes to headphone amp via aux sends to headphones but since i purchased a ssl sigma i take my sends from the aux output on the ssl to the headphone amp its a main out i have yamaha replica ns10s headphones either way it’s a rubbish sound in the headphones :) I do not use headphones to mix ..i use the hs50 s
getting rid of muddy vocals chalz2502 Pro Tools 10 8 07-27-2015 10:40 PM
POD 2.0 muddy ! jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-28-2008 09:21 PM
Muddy voiceover help? Adman44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-20-2005 01:32 PM
psp vintage warmer is muddy.... Tedmod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2004 05:12 AM
Guitars in the mix are muddy,bassy platinumx99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-28-2003 06:30 AM
