Old 03-08-2011, 09:20 AM
justus1900 justus1900 is offline
Default Pro Tools 9 Mixing on a Laptop SD Card
If IM using Pro Tools 9.0.1 on a Windows 7 Laptop just for Mixing can I load the song onto a SD Card and use that as my Session Drive for Mixing while using the OS drive for Pro Tools 9? Will it work?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 03-08-2011, 01:16 PM
misterdmz misterdmz is offline
Default Re: Pro Tools 9 Mixing on a Laptop SD Card
I've done this with a 4gb usb drive. Session folder was about 1gb in size, 30 or so tracks, moderate amount of plugins. Worked the mix for about 20 mins with no errors.
Old 03-08-2011, 04:12 PM
Has anyone ever used a SD Card Formated to NTFS for Playback of a session while Mixing on a Laptop with one internal Hard Drive? I want load Pro Tools 9 on the OS drive and us the SD Card as the session drive. Does it work, will it work? or should I try and use a USB drive?
Main:
JBL LSR4328P 8"
Mixing on a laptop tdblanchard macOS 5 05-23-2013 07:57 AM
anyone mixing for TV in LE on a G4 laptop? inky Post - Surround - Video 19 08-16-2006 02:09 PM
mixing/editing on a laptop PlainJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-23-2004 05:01 AM
Mixing PT on a G4 laptop kirk95 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-02-2003 09:13 AM
mixing on a laptop...do I need the 002 connected? BeachDog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-06-2003 12:44 AM
