Time compresion expansion
What's up first post. I am using pro tools 6.2.2 and when I use TCE the waveform becomes almost nonexistant, also is there a way to fine tune the BPM's. For instance I am going from 77 BPMs to 75 BPMs but using the ratio it will only go to 75.012 or 73. something. I'm trying to match tempos between two audio regions. Any help is appriciated thanks, peace
Re: Time compresion expansion
If you want to input exact numbers, then use the AudioSuite Time Shift plug-in. It will allow you to type in the desired length time or tempo.
Paul Peterson Sound Director The Old Globe San Diego, CA |
Time shift is not compatible with PT 6. If I were you I would match it up by samples. Highlight the region that would be the source region. Switch your time ruler in PT to show samples, and look at the length. That is what you want your destination to be in the plug-in. In other words thats what you want the plug to expand or compress to by sample length. Go ahead and highlight the region that you want to expand or compress and type in that sample number into the destination of the plug-in, make sure you hit return so that it locks the number in and the field turns green and doesn't stay white, and then hit process. It should make that the same sample length as your source region.
AKA - EvilElfHobo Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4 Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified. Multi-Platinum Pro Tools Videos |
I will give it a try, Thanks
Cool deal.
Expansion HD time out | AvE4489 | Pro Tools TDM Systems (Mac) | 3 | 12-25-2012 03:41 PM |
L2 + POWr + Multiband compresion | aziel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2004 10:33 PM |
Recording Vocals with Compresion | supercell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-22-2003 04:10 PM |
Time Expansion | Clinton Smith | Digidesign Hardware & Software | 1 | 06-15-2002 08:56 AM |
time compresion error...oops? | monkey | Pro Tools TDM Systems (Mac) | 6 | 11-29-2001 12:35 AM |
