Disk Cache
Merry Christmas to everyone!
I'm experimenting with disk cache but I have a couple of questions (Yes I did search before posting) 1. How does it help when recording? Say I have 1Gb setted for disk cache, does it react as a buffer for the HDD / SSD? 2. At playback, say if I have 1 Gb allocated and the project has more than that. I suspect it loads from where the cursor is located in PT and if I move it to a part that's not charged into the cache it starts loading that part? Thanks,
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
Re: Disk Cache
Doesn’t help with recording; only with playback (once you stop recording, the new file can be cached)
Re: Disk Cache
It helps with recording by offloading concurrent read IO from drives. Most useful with HDD with large seek time compared to SSD.
Disk Cache
I leave it set to default when recording. I have had errors when the cache gets full. Not sure why, I found that default all but eliminates the errors. I have SSDs and an HDX system on my PC. I leave it at default on my MBPr also for the same reason.
Sent from my iPhone using Tapatalk Pro |
Re: Disk Cache
Re: Disk Cache
Yep Normal. No cache.
Re: Disk Cache
So from what I understand with SSD it’s better set to normal, right?
Thanks
Re: Disk Cache
It's clearly likely to be better set to a size to hold your whole sessions. Or if that's not possible try it set as large as you can and see. See what works for you. |
Re: Disk Cache
Yes it helps on recording, you can even record to a slow usb stick if all of your session fits in memory... just dont touch anything once PT starts writing to the stick 😂
Re: Disk Cache
So it does act like a buffer for recording, on your opinion. Thanks,
Could not allocate memory for the disk cache. Try lowering your disk buffer.. | slim_shady | Pro Tools 10 | 15 | 05-09-2017 05:20 PM |
disk cache | Benne | Getting Started | 3 | 09-12-2013 05:11 PM |
PT10's Disk Cache or RAM Disk. Why not use the same concept for VI memory space? | sunburst79 | General Discussion | 6 | 09-15-2011 11:28 AM |
disk cache | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-08-2001 07:51 AM |
