Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-12-2021, 09:42 AM
josoro505's Avatar
josoro505 josoro505 is offline
Default No Quicktime option under Bounce
Now, this has worked in the past. I did an assignment a few weeks ago and bounced an mov file of the video with audio attached.
Here, you can see, the video is selected and highlighted; however, the Quicktime option is greyed out.
I looked online and found several postings, but they mostly advised making sure the video is selected.
I have not updated my PT version since the previous successful Quicktime bounce.
Please advise.
OMEN by HP Laptop 15-dc1xxx
Intel core: i7-9750H-CPU 2.60GHz 6 Cores, 12 Logical Processors
NVIDIA GeForce GTX 1650 Version 451.67
RAM: 32Gb (31.8 usable)
Windows 10 Home x64
Running PT 2020.9.1
Old 04-12-2021, 10:38 AM
BScout BScout is offline
Default Re: No Quicktime option under Bounce
Video selected doesn't matter.
Is Video Online? (blue "O" lit up on the video track)
Old 04-12-2021, 10:51 AM
josoro505's Avatar
Yes. It is online.
Windows 10 Home x64
Running PT 2020.9.1
Old 04-12-2021, 03:50 PM
Reinstall your Quicktime Components. From the 2020.9 notes:
Installation of QuickTime Windows may fail with a application hang (PT-243411)
The installation of Apple QuickTime may hang and must be force quit on the Windows Operating System. This can occurs regardless
of your Pro Tools installation. If you encounter this issue, install all Microsoft Windows updates available for the system and try again.
If problems persist, consult a search engine for the latest troubleshooting information as the steps to work around the problem can
change over time based on Windows Updates installed and available status.
Chance a Windows Update borked it. Can't remember if QT has a separate installer.
Old 04-12-2021, 07:04 PM
josoro505's Avatar
Thank you. It is probly cause I am a total PC user and shy away from Mac.
The issue must be something simple.
Windows 10 Home x64
Running PT 2020.9.1
Old 04-13-2021, 10:38 AM
The Weed's Avatar
The Weed The Weed is offline
Have a look here if you want to install the minimum QuickTime.
If not QuickTime, you may need to install the latest Avid Codecs, look here.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-15-2021, 09:16 AM
josoro505's Avatar
Problem solved!
Thank you.
2019.6 Bug? Quicktime bounce w/o sound when online bounce peterle Pro Tools 2019 6 09-07-2019 12:27 AM
No Bounce To QuickTime Option davydp Pro Tools 10 0 06-03-2015 03:35 AM
No Bounce to QuickTime movie option? dg27 Windows 2 02-25-2015 11:17 AM
Quicktime Bounce Option menu sean c Post - Surround - Video 4 03-22-2011 02:32 PM
AV Option & Quicktime D Drew Pro Tools TDM Systems (Mac) 0 11-27-2000 12:27 AM
