Old 09-10-2015, 05:35 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default PT12 and El Capitan
Now that the GM is released, anyone brave enough to try it on 12.2, or even 11.3 for that matter?
I know Musicman, first have a solid backup, never install unsupported OS, yada yada...
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 09-10-2015, 05:47 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: PT12 and El Capitan
Why don't you try it out if you know Jack's advice :P?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 09-10-2015, 06:17 PM
Cliffy_Boy's Avatar
Downloading now. 6gigs!
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 09-10-2015, 10:20 PM
dr_daw's Avatar
Keep us posted. If I recall correctly others had poor results. What does El Capitan offer that you need?
Rig
Old 09-11-2015, 02:52 AM
smfelton's Avatar
smfelton smfelton is offline
Running on a test drive, with no noticeable problems, not done any serious work on it yet (well you wouldn't would you) but all looks ok so far.
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 09-11-2015, 04:50 AM
Drew Mazurek's Avatar
PT's been working fine on almost all the El Cap builds.
www.drewmazurek.com
Old 09-11-2015, 05:09 AM
Oliver M Oliver M is offline
Well, have you tried to import audio Drew?
Command+Shift+I
Its not working for me. Drag & drop does though.
Old 09-11-2015, 06:13 AM
Command+Shift+I
Of course I am not doing real work on an unreleased OS, so I haven't tried anything beyond launching, opening sessions and doing some basic things. All of which seemed fine.
To expect an unreleased OS to work perfectly with an App that hasn't been updated to support it is of course silly. The goal now is for all of us, in our spare time, to help Apple and Avid make the transition smoother.
Will try to Import later today if I have time.
www.drewmazurek.com
Old 09-11-2015, 08:07 AM
Cliffy_Boy's Avatar
So far all I see is on 11.3.1 the program hangs while opening at the midi editor. Takes 10 minutes and then opens. My midi tracks are there but I don't know if midi is working yet.
In Audio MIDI setup, in Utilities on the Mac, Midi doesn't open so I think this is a OS thing.
And the Avid S3 Led screens just are a big blob of yellow so unless that's fixed in 11.3.2 or 12.2, the S3 is on hiatus.
I'll play more this weekend and see if there are other glitches.
This all may be 11.3.1 related. Who knows since 11.3.2 is AWOL
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 09-11-2015, 08:33 AM
zion zion is offline
So far the only issue I've found is the VU meters and the transport counters display run a little slow on my dual monitor setup. I see no performance difference. Maybe these thing will change with the final release and when Avid approves it. Edit I forgot to mention this happens when several plugins are open.
M-Audio Fast Track Ultra on El Capitan hoss33 FireWire & USB Audio Interfaces (Mac) 267 07-24-2016 07:48 PM
Problem With 11R, PT 12 & El Capitan donebylee Eleven Rack 18 10-30-2015 01:04 PM
El Capitan mastertstudio Pro Tools HDX & HD Native Systems (Mac) 21 10-25-2015 02:55 PM
PT12 and PT12 HD surround? theom Pro Tools 12 17 10-12-2015 09:27 AM
El Capitan beta beware! clausiii Pro Tools 12 1 07-16-2015 12:23 AM
