Old 09-13-2011, 09:40 AM
02bhopkins 02bhopkins is offline
Default start up help
hi,
i have just purchased protools 9, so slowly learning the ropes with regards to that, i am running my mixing desk into my profire 2626, which is inturn connected through firewire into my tower. having spent hours trawling the internet trying to find help, i still cannot get a signal through to protools. i have checked it is selected as my hardware, then checked my i/o and they are all set to default and indicating that everything is ticker de boo. however when i select my channel record selecter there is no signal bouncing up and down in the track meter. would really appreciate some help with this one. thanks alot!!
Old 09-13-2011, 12:20 PM
Default Re: start up help
Troubleshooting is best done by breaking things down to the bare minimum. I would start without the mixer and plug mics into the 2626 fot testing. Make sure you have phantom power on if you use condenser mics. Other things to check(I don't own a 2626); mic/line switches, are you using audio tracks(not instrument tracks) and, is the 2626 the selected audio engine(hold N while opening PT to select).
Old 09-14-2011, 10:16 AM
hi,
the mixer isnt the problem im afraid, im getting signal lights appearing on my 2626 inputs. which for me rules out my mixer, i believe my problem lies between my 2626 and pt, there must be something not set correctly or something blocking it, i just cant find out what
Old 09-18-2011, 10:35 AM
can anyone help???
Old 09-18-2011, 12:37 PM
Hold the N key while opening Pro Tools and make sure you have selected the 2626 as your audio engine.
Old 09-21-2011, 10:26 AM
ok, done, its saying that my 2626 is the engine, still nothing on the track meter though,
Old 09-22-2011, 06:33 AM
BaileyBass BaileyBass is offline
Do you have another interface that you can borrow to try.. could be the output stage of the 2626.. or use it with another software and see if it works there.
Are you inputs (in I/O setup) showing the n/a???
Drivers up to date?
Reinstall PT?
Can you send audio from one track to another. drag a loop in and see if you are outputting anything.
Has this ever worked? sb
Old 09-23-2011, 10:38 AM
hi,
ive reinstalled PT twice, in my I/O page i cant see anything saying N/A ? is that where things are going wrong?
all of my drivers are up to date,
and no i cant send one track to another,
strange as it sounds, yes pt has worked with my 2626, but im only talking for a max of 30seconds sometimes, and then others a split second, and the track meter will freeze in its last know level, and when i restart PT it doesnt work again.
its baffling to me
[IMG] code is Off
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 11:06 AM
Downloaded PT 8 and it wont start PT logo moves but doesnt start????????? protonneutron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2008 03:25 PM
Can I start Playback at Session Start Time? LSW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2006 03:04 PM
Start-Stop-Start again NOT from beginning mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-23-2004 04:05 PM
Pro Tools 5.1 Session Start—Record Start Interval Avid Pro Tools TDM Systems (Mac) 4 04-18-2001 08:27 AM
