Monitor Outputs - Digi 001
I just installed the Digi001 this weekend (forgive me if my question is a stupid one...) and it seems to work except my active monitors. I can playback an audio-sample through headphone, but not through the monitor outputs. When I put the output on Output 3 & 4 and I connect the speakers to these channels I have sound, but I'm doing something wrong with the monitor outputs.... Can anybody help? (Monitor Mode is off) Thanx in advance.
Woodman |
Re: Monitor Outputs - Digi 001
Try connecting your monitors the the main in/outputs. If you do so....make sure you play back sound very very low in volume, or better....before connecting your speakers, create a masterfader, and close it. The after you connected the speakers, play back a session, and open the fader very very careful.....
If you get sound this way....i siggest you check your cabling again.....and the position of the monitor-switch.... Also make sure the "vol" knob is opened a bit...(its next to the green power-light on the left...)
What's that? - That's the machine that goes "pling". Bastiaan |
I actually had the same problem. It seemed that because I had already installed the card awhile before I installed PTLE audio wouldn't travel through my digi and then through my monitors. I simply uninstalled PTLE opened my tower and pulled the digi card. I then reinstalled PTLE and then my card in that order. After set up was complete my monitors were working through the digi just fine. [img]images/icons/grin.gif[/img]
I got an ant farm. Those fellas didn't grow jack - Mitch Hedberg, (slightly modified) |
Digi 002 static/distortion from Monitor Outputs and Headphone jack | CyberTribal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-22-2013 07:31 PM |
Digi 002 Monitor Outputs | elandrue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-21-2009 07:04 AM |
HELP with Digi 002 ALT monitor outputs?? NO VOLUME | Johnny916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-10-2004 07:33 AM |
Digi 002 monitor outputs balanced or unbalanced? | coryc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-19-2004 07:22 AM |
Monitor Outputs??? | Dinkus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-09-2001 08:52 AM |
