hi, well i hardly ever use Slate Drums and decided to use it today .. that was a bad idea .. midi showing in instrument track but not on channel, midi showing in the SSD$ program fine but not on fader ..
and trying to Map drums from Abbey Road over to Slate .. crash PT12 .. i looked on slate site but see no updates .. is anyone else having these issues ?? cheers and thank you john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version Logic Pro X latest version RME BabyFace Pro Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here .. Logic Pro X latest version RME BabyFace Pro |
Slate Drums has been flawless for me...OSX 10.8.5, Pro Tools 12.1.
I see you're on 12.2.1...Did SSD work for you before the latest Pro Tools update? I haven't updated yet because I am scared of things like this... |
hi alex, it worked before the update to PT11 but it has been awhile since i used it as i think i may have had issues then as well .. just cannot remember ..
I would contact Slate support with all your specifics and let them know exactly what is going on. Slate support has been stellar for me in the past. Good luck!
i will call them, just thought i might be able to type a note here and stay working instead of troubleshooting the day away AGAIn ...
i left a message as no one answered the support phone .. weird ..
slate is running now .. have no idea why it acted how it did .. i have a question on mapping .. i use Abbey Road drums as well as Slate .. i cannot seem to find out what Mapping Protocol Slate uses .. i will ask when they call back .. hopefully .. so i build a kit in Abbey Road (AR) and want to move it to slate .. if i map it before i start in AR with the protocol for Slate i would think i could drag Midi Clips between them and just need to deal with Velocity differences .. in Slate there is a way to change mapping but not From AR to Slate .. only the other way round .. does anyone know what to use in AR to get the drums to map correctly in Slate ?? thank you john
Something similar happened using one of the a bundled PT instruments. I opened a second instance of Mini-Grand on an adjacent instrument track. I could see the MIDI meter was active but no audio signal coming through the instrument fader. I double checked the MIDI output routing and made sure it was output to "MG2" but no audio signal. I could however, route it to the MG1 track and get a signal.
So I created a new instrument track fresh for Mini-Grand 2, assigned the output accordingly & then dragged the midi file from the previous track onto the new track and it worked fine. Since the session was was older, so I don't know if I had duplicated the previous track and it's properties or if that might have had something to do with it. In any event, will let you know if it happens again. Are you using SSD 4? I use SSD 3.5 within Kontakt 5.5 nearly every session and haven't experienced any problems. Last edited by take77; 10-29-2015 at 01:20 AM. |
i am using SSD4 (the custom version) with blackbird expansion ..
![]() Quote:
since i am still waiting for slate to return my support call ..
hi Alex, i have never had this happen before .. thx for the info
Slate Digital and Steven Slate Drums AAX | DHL | AAX Plug-ins | 6 | 04-22-2013 12:50 PM |
Steven slate drums help with Hi Hat | Raoul23 | The Drum Room | 4 | 03-13-2013 07:21 PM |
Steven Slate Drums 3.5 vs 4. | yamahadrums | The Drum Room | 9 | 02-05-2013 01:34 AM |
PT8 LE and Steven Slate Drums | outlaw69uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-30-2010 08:00 AM |
Anyone Using Roland TD-9 Drums with Steven Slate Drums? | Troy Tracks Studio | The Drum Room | 2 | 05-05-2010 06:55 AM |
