Old 04-19-2004, 06:15 AM
syntax syntax is offline
Default can\'t open files session files .....plz help...
Hi
i am runnig protools 6.1.1 on windows xp with digi001. Everthing seems to work fine but from some reason i can't open big session files...
when i am trying to open big session it stucks the program and try to locate fade files till the application is terminated.....
i can open small projects...small session with no problem but only when i try to open the big sessions it wont open them !
the sessions that i am trying to open - i did with older version of protools ( 5.1 ) so maybe this is the problem ...but how do i fix it?????
plz help !!!!!
Thanks !!!!!!!!!!
Old 04-19-2004, 06:23 AM
Bazzle Bazzle is offline
Default Re: can\'t open files session files .....plz help...
Have you tried to open the session from within Protools?In other words open up Protools and then go to File>Open Session and open the session that way.Just an idea
Bazzle
Old 04-19-2004, 06:29 AM
i have tried that....same problem.....any other ideas?????
Old 04-19-2004, 06:33 AM
Do you have enough RAM now that you have 6.1.1?
Bazzle
Old 04-19-2004, 06:44 AM
512 mb ddr...
pentium 4 - 1.8 ghz
mother board - asus p4t800
Old 04-19-2004, 06:46 AM
I don't know what to say, someone else will probably have some ideas.
Bazzle
Old 04-19-2004, 06:47 AM
thank man.....
anyone else?????
Old 04-19-2004, 07:09 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Create a new session in PT 6.1. Then choose File - Import Session Data and import the 5.1 session into the new session. Make sure to select each track from the old session you are importing and choose convert if the bit depth or sample rate are different.
The new session could work.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Cant open my session or the audio files on same or other PT rig cloudchamber Pro Tools 10 1 02-25-2014 05:52 AM
Can i open a session/files recorded on a tdm HD with 003? valleysounds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-04-2007 09:16 PM
Can Pc Session files open on a mac running 7.0? gobzilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2007 05:38 PM
Open Files from TDM session in LE baugh05 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-15-2002 08:18 AM
5.1.1 session files open in 5.0.1 with no tracks?? fshrking Pro Tools TDM Systems (Mac) 3 01-26-2002 11:17 AM
