set the volume to 0db. then calibrate with -20 pink. 0db = unity.
from there you can change it to spl mode and specify the spl you set 0db to, ie 79, 82 etc
Ken Wilkinson http://kenwilkinson.tv Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1 2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5 |
Thanks for your reply Ken...
"set the volume to 0db" means on the OMNI itself? Signal Generator to -20dbfs Pink Noise RMS or Peak? |
correct
Hey Ken, I see you're also using the JBL LSR 4328 5.1.
When you calibrated the levels on each speaker, did you use RMC first or after? And while you were calibrating, did you have the sub gain at +10db (which is separate from all the speakers +4/-10)? Thanks!
-Mac Pro 5,1 12core 3.46GHz Westmere 96gb -RX 580 8GB GPU -OSX 10.13.6 on a 1TB SSD Via PCIE card -PTHDN 2020.12 Ultimate -HD Omni -BM Intensity Pro -Waves Mercury+SSL4000 Collection+Abbey Roads -iZotope RX7 Advanced -iZotope Post Production Suite 4 -iZotope Music Production Suite 3 -HALO UP/DOWN MIX -ANYMIX -Delonghi Perfecta ESAM 5600.S |
Yes I calibrate after RMC and b-chain equalization. Sub is +10 engaged. I don't have a RTA so I followed Dolby's guideline to calibrate the sub 4-6dbc above the center channel.
![]() Quote:
Mostly mix for film, but sometimes it can also go straigh to Blu ray or theater and BR release and streaming. What is the consensus that everyone is setting their too? And also to confirm, have the Sub at +10 AND also set the levels on that to 89db? Thanks so much
FS: Avid HD Omni interface | friendlybunny | Buy & Sell | 2 | 08-08-2013 07:53 AM |
HD OMNI isn't truly 8 output ... | agershon | Pro Tools HDX & HD Native Systems (Mac) | 9 | 06-12-2013 10:00 PM |
Omni interface...4 tracks only? | mzkguy | macOS | 2 | 04-23-2012 08:17 PM |
omni output question | FilterDecay | Pro Tools TDM Systems (Mac) | 6 | 10-26-2011 02:46 PM |
Are Omni Analog ins calibrate-able? | Picture Start | Pro Tools TDM Systems (Mac) | 7 | 10-07-2011 08:07 AM |
