Re: PT5.0 and Extended drive format
Dog BBQ: Yes, and yes.
Coaster: Yes. The "lag time" only occurs with HFS+. No way around it, since it's a function of the number of allocation blocks. ------------------ --Steve Rosenthal, Digidesign ETS
--Steve Rosenthal, Digidesign ETS |
Steve -
We are looking into getting a new set of hard drives (I run two 9GB Glyphs right now - which are starting to run out fast @ 24 bit...). Can you explain more about the record lag with HFS+ and the "fix" you mention? Do you have to designate "I am going to record for 5 minutes"? That's a pain, since we are doing dialog work and a team could go for 25 minutes without pause or for 10 seconds and need to take a break... While I'm at it, what is the best drive to get right now? I won't need it desperately till after 5.0 is out (assuming it arrives ontime), so would hfs+ be best? Thanks! -adam |
OS Extended (HFS+) format Ext Drive | Eric_J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-09-2006 05:01 PM |
OS Extended (HFS+) format Ext Drive | Eric_J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-09-2006 04:54 PM |
Format Drive Extended??? | football2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-10-2006 03:54 PM |
format external drive to OS X extended? | pietervd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2006 03:11 PM |
Extended hard drive format | Dog BBQ | Storage Subsystems | 2 | 11-05-1999 10:35 PM |
