Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 07-28-2022, 12:36 AM
RackAddict RackAddict is offline
Default Omni Input 5 flashing with higher sample rates.
Just want to start using 88.2k sample rate or 96 and all. See now when ether clocking internally or externally to an antelope is input 5 on the omni flashing the maxed clip meter. This only happens when switching the sample rate to anything above 48k. This is the weirdest possible thing to happen. I already tried the reset procedure.
Sent from my BBE100-2 using Tapatalk
Old 07-28-2022, 12:43 AM
Default Re: Omni Input 5 flashing with higher sample rates.
Nevermind. Fractal Axe FX 3 on AES mode only 48k possible. Just horrible.
Performance disadvantages with higher sample and bit rates scott llamas Pro Tools 11 12 11-15-2013 05:15 PM
PT9 A&H ZED-R16, no playback at higher sample rates redbull Windows 10 09-20-2012 10:04 PM
ADAT, AES, higher sample rates Uli Rennert macOS 0 04-19-2011 08:23 AM
44.1 vs. higher sample rates Stacyodell Pro Tools TDM Systems (Mac) 88 09-22-2007 10:37 AM
any arguments against higher sample rates like 96? Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-08-2004 09:33 PM
