Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 10-20-2020, 01:32 AM
m4tune m4tune is offline
Default Commit up to this insert...
I'm confused…
When trying to commit clips from AAX-Melodyned track I get this:
A consolidated stereo track!
- up to this insert is choosen from right click menu at the first plug-in
- consolidate is unchecked in the dialog
Please see screenshots, too.
Anything I did wrong?
Any help very much appreiciated!
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6
http://www.4tune.at
Old 10-20-2020, 02:16 AM
midnightrambler midnightrambler is offline
Default Re: Commit up to this insert...
Yeah it’s a bug, it’s also killed your stereo reverb plug-in if you notice. Happens whenever you try to commit a mono track “up to this insert” with a stereo plugin further down. Been like this since the feature was implemented.
Basically you have to take your stereo plugin off the track (move it to a dummy track maybe), consolidate up to insert, and then re-insert the stereo plugin on the commited track.
The first time I got caught with that was a air-turning-blue kind of day
Old 10-20-2020, 02:34 AM
Removing the stereo plug-in solves the issue that a stereo track is created.
But still all clips being consolidated with unchecked this option in the box…
http://www.4tune.at
Old 10-20-2020, 04:03 AM
Don't know about that I'm afraid, I always consolidate. Someone else may be able to chime in.
Old 10-20-2020, 07:15 AM
daeron80 daeron80 is offline
In my experience, clip boundaries are only maintained when there is space between them in the original track. Overlaps, abutted clips, and fades seem always to result in consolidation.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-20-2020, 09:16 AM
When I commit a track with Melodyne, I always ONLY commit from Melodyne(which is always in the top insert). I also never put a reverb plugin directly on an audio or instrument track(I always use reverbs on an AUX track and feed via a send). What you describe may well be a bug, but I highly recommend changing your work flow a little. If you're asking "why"(which is a good question), here are my reasons:
#1-With this method, I have never experienced the issue you describe***.
#2-I ONLY commit Melodyne as I prefer to keep tuning as totally separate from mixing(and all the following plugins are all about mixing)
#3-Reverbs run as inserts are; A-an inefficient way to use reverbs(which tend to use more cpu than other plugins) and B-no matter how you set the MIX control, you will lose volume on the track(unless the MIX is set to 100% dry, which is not likely to happen).
***With Melodyne, I also select Do Nothing to the original track, let the COMMIT complete, then I create a new playlist on the original track(and name it "Trackname.TND"). Then I copy/move the tuned audio onto this new playlist(keeping the original un-tuned audio as its own playlist) and delete the(now empty).CM track. At that point, I may remove Melodyne, or make it inactive(in case I feel I may need to revisit). If you're thinking this seems like a lot of extra stuff, you may be right. But having done this stuff as long as I have, maybe I've been bitten in the butt a few more times
Old 10-20-2020, 11:20 AM
Dave ftw!
David J. Finnamore
Old 10-20-2020, 01:58 PM
You raise good points and workflows, but there are plenty of instances where you might want to use a mono-stereo plug-in on a track other than a vocal (an auto-panner being a super obvious example for instance). Committing anything above this mono-stereo plug results in a) a stereo file being needlessly created and b) the stereo plug-in being "disappeared", in that it's not printed, but not 'live' on the track either. This is (in my book) a textbook example of a horrible bug, which I reported ages ago, and still waiting for something to been done about it.
Old 10-21-2020, 02:18 PM
Originally Posted by midnightrambler View Post
…This is (in my book) a textbook example of a horrible bug, which I reported ages ago, and still waiting for something to been done about it.
Thanks!
And there are always work-arounds of the uneasy things that AVID is ignoring for their very expensive yearly tax!
I think it's pointless to lecture someone who is aware of basic routing examples we all learned decades ago in school or from the basic books out there.
I'm 20+ years in the business and I'm so sick and tired about getting comments like the one from Dave 1952…
Couldn't stand the community more together and call louder for ARA to be implemented?
That was my real reason to report this, btw.
http://www.4tune.at
Commit up to this insert michael c Pro Tools 12 8 07-27-2018 08:31 AM
Commit Up To This Insert bug with mono>stereo plugin jacko Pro Tools 12 5 06-02-2018 09:54 PM
Two issues (bugs?) found when using "Commit Up To This Insert" midnightrambler Pro Tools 12 7 10-15-2016 08:27 AM
"Commit up to this insert" resets Slate Mix Rack jonathan jetter Pro Tools 12 4 04-30-2016 04:42 PM
Commit up through this insert? Carl Lie Pro Tools 12 7 01-24-2016 10:23 PM
