I want PT-Control for Pro Tools only
I use mainly Logic X 10.2 for Mixing and also the Logic Control. Pro Tools 12.4 I use for Recording. The PT-Control for Pro Tools is running also, but if I start Logic, it looks for EuCon Support, and it takes a while until it starts. It's sience I use the PT-Control. Usal I switch Wifi off, and use the Logic Control over Blue Tooth if I want.
Is there a possibility to switch the EuCon Support for Logic and for Cubase off, or oposite that I can use it in Pro Tools 12.4 only.
MacBook Pro Quad 2,3Ghz i7, 16GB Ram, 64Bit Pro Tools 2018-12, Logic X, Cubase 9.5 Eleven Rack |
Re: I want PT-Control for Pro Tools only
Will you focus Pro Tools, then go to EuControl Settings>Assign tab and check the boxes for "Lock to Application"? That might resolve this.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
This works only as long Pro Tools is started. If I quiet Pro Tools 12.4, all this locks gone.
Logic X 10.2 is still try to start the EuCon-Support by the startup, what may is not the same as the EuControl, but it is deppendet on that and on the PT-Control. Only WorkOut at the moment to start Logic X faster is: I switch the the Computer-to-Computer Wifi on, and the iPad Air2 with the PT-Control. If Logic X is up, thenswitch this things down. edit: I deinstalled the EuControl now, to see what is happen. Logic X starts without starting the EuControl. Before I thought it's not command to use Logic X and Pro Tools and don't want to use EuControl if Logic is started, but I find one article here about that. Unfortunately there was only curse, what is not a solution. I don't want to read those stuff.
MacBook Pro Quad 2,3Ghz i7, 16GB Ram, 64Bit Pro Tools 2018-12, Logic X, Cubase 9.5 Eleven Rack Last edited by Yehudi; 01-14-2016 at 03:41 AM. |
choose to not have EuCon startup with computer .. this should give you the option to have it NOT open when logic opens .. you will just need to start it manually when using PT ..
just .02
that makes only that the EuControl not start with the Computer, but it doesn't switch Logic off from to start the EuCon-Support. That's also why I mean it's not the same, but it's on some way connected.
I don't think there is any way to disable EUCON in Logic. You can disable it in Cubase via Preferences.
How long would say it takes Logic to launch when EuControl is installed/running vs. not installed? I assume that if Logic didn't take longer to launch with EuControl installed, your issue would be resolved?
We can count the time only, with the Logic-Screen (simular to the the Pro Tools or Cubase Screen in the beginning until this both ask what song shall be open) without around 10 seconds, with EuControl over one minute. Logic X start always with the last song or what you chose from the dock after the screen. This time after depend on the song.
Maybe it's possible to hide the EuControl for Logic?
Pro Tools | Control vs. Neyrinck V-control pro | dr_daw | Pro Tools 12 | 35 | 08-17-2015 03:38 AM |
Midi Control Not working in Pro tools 11.0.1 but works in pro tools 10.3.6??? | bleudog | Pro Tools 11 | 17 | 04-30-2014 03:13 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
A new way to control Pro Tools? | Vaphoron | Pro Tools TDM Systems (Mac) | 2 | 10-30-2002 08:45 PM |
Logic Control to control Pro tools : Brilliant !! | PGrealy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-10-2002 11:46 PM |
