Old 01-18-2019, 02:14 PM
audiocontrol audiocontrol is offline
Default PT 2018.12.0 LLM overcompensting latency ?
Hello guys,
I'm experiencing some issues here.
OSX is 10.12.5
PT 2018.12
In Low Latency Monitoring PT seems to overcompensate the latency, meaning that whatever I play back is a little bit ahead of what I recorded.
When I turn off LLM it is correctly set.
Changing the buffer doesn't affect this in any way. It's not getting worse or better.
Whats the issue ?
Thanks
Sascha
PT 2018.12, Mac Pro, HDX, S3.
Old 01-19-2019, 05:51 AM
Default Re: PT 2018.12.0 LLM overcompensting latency ?
Interface is an Apollo8 Blackface.
Thunderbolt.
Seems like the Apollo is reporting the wrong latency to PT ?!
Anyone ?
Old 01-19-2019, 02:12 PM
edwinstar's Avatar
edwinstar edwinstar is offline
can you check if it is happening only on tracks that are record enabled?
Old 01-19-2019, 02:45 PM
If only I knew how to record on a track that is not record enabled...
Old 01-19-2019, 04:04 PM
edwinstar's Avatar
seems like you didn‘t get it...
Gesendet von iPhone mit Tapatalk
Old 01-19-2019, 04:07 PM
edwinstar's Avatar
check if there is a difference in timing between playing back your newly recorded audio when the track is still record enabled and when it‘s not. also check the numbers in the delay comp window.
if there is a difference, then yes, it‘s a bug.
go back to pt 2018.4.
Pro Tools 2018.1 low latency monitoring issues stakeoutstudios Pro Tools 2018 61 04-15-2020 07:15 AM
Low Latency Monitoring different in PT 2018.10 and HD Native? katerkarlo Pro Tools 2018 11 03-31-2020 01:50 PM
2018.7 low latency Recording question RobertDorn Pro Tools 2018 3 09-28-2018 11:45 AM
PT 2018 - Low Latency Monitoring issue: mutes signal briaboy Pro Tools 2018 5 06-25-2018 04:23 AM
PT 2018.1 with MBox 3 USB latency RichrdC Pro Tools 2018 2 02-23-2018 04:39 PM
