Eleven Rack with HD issue
These is no way to be able to get to clock to 44.1 It stuck on 48K (there is No control of the clock and digital I/O setting when using it stand alone) so I get little clocking glitches with 44.1 sessions.
Re: Eleven Rack with HD issue
Obviously this is more of a workaround than a fix. But it might let you at least keep working in the meantime. Oh yeah, you have to make sure you plug into the digital "card" in the back of the 192 and not the enclosed digital ins off to the right on the back of the unit.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
I am not able to use my 192 Digital Card inputs as they are all used up so I am using the Digital Enclosure settings which has no real time sample rate convert.
Plus If I am using this with a non-protools setup in stand alone not being able change these basic settings is show stopper. |
Greetings,
I posted the following in a thread on the Duc Guitar forum. Quote: Originally Posted by sunburst79 Not to hijack the thread but can you possibly post a comprehensive guide for using the 11Rack with the 002 and 003? Since we cant clock though AES. I have not figured out how to get Eleven Rack to sync to an incoming AES signal... I figured I was doing something wrong or missing a setting (or had a bad cable, or any other number of things...). Is it actually not possible? Right now it says "External Clock: Valid," but the clock source is Internal 48k. I have 11R set up with AES out into a 192 digital card and AES in from that same card - so it is a loop. But it doesn't appear to be getting sync... and I was getting a nasty scratchy noise (until I switched on SRC on a tip from this thread). So, am I doing something wrong? Should I be able to get it to lock to incoming AES. Note... nothing is selectable in the Digital/Clock Input screen. Thanks, Jared |
Use the Prefs. pane The manual sure is sketchy on a few important details
I was confused on this... thought I would post so it was 100% clear to everyone. Setting the sync preferences is in a preference panel in "System Preferences" for the OS (where you would set your screen saver, mouse settings, boot drive, etc). Once you load the Eleven Rack software, you get a little preference icon in the "other" section at the bottom. This is NOT in Pro Tools.
Issue with i/o after eleven rack use | jimbridgman | Eleven Rack | 2 | 02-11-2014 09:14 PM |
Eleven Rack demo issue | GregMann | Eleven Rack | 4 | 04-19-2013 08:49 PM |
Eleven Rack with protool 10 issue | Rogerwolff | Windows | 4 | 02-07-2012 01:21 AM |
Eleven rack issue | dndunlap | Eleven Rack | 4 | 03-08-2011 11:35 AM |
Recording with Eleven rack issue | Tolstoy69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-28-2010 10:57 PM |
