PT LE 5.2 error 1,010 occurred
Upon starting PT I get this:
"The application has unexpectedly quit, because an error of type 1,010 occurred" Anybody know this one? Thanks, Stan |
Re: PT LE 5.2 error 1,010 occurred
Although I'm not sure of an exact fix, here are a few suggestions to try:
-Trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac. -Open the Sound Control Panel and set its output to "Built-In". -In Extensions Manager, create a Mac OS Base set, enable the following extensions and restart the computer: -Digidesign Control Panel -DigiSystem INIT -Digidesign Direct I/O -Digidesign DSP Manager -Digidesign Stream Manager -Open Music System -USB Floppy Enabler Brent |
I had this error recently. Tried the usual fixes (delete prefs, digiset-up etc) - as Brent has pointed out - but never managed to fix the problem fully - my guess that either PT or DAE itself had become damaged in some way???. In the end it was a clean install of PT to get it all back, having trashed all of the original install. My error was in PT LE 5.2.1 - I went back to 5.1.1 and have been running OK since. Good luck.
-To remove all Pro Tools releated items on your hard drive before reinstalling... trash the following: -------Digidesign folder from System folder: -------DAE Folder (remove all third party plug-ins and custom presets) from Control Panels folder: -------Digidesign® from Extensions folder: -------DigiSystem INIT -------Digidesign Direct I/O -------Digidesign DSP Manager -------Digidesign Stream Manager From Preference folder: -------DAE prefs -------DigiSetup -------ProTools preferences Brent |
Bo, Brent thanks for the info, I will give it a try when I get home in the morning.
Stan |
Cpu Overload Error Occurred. "NEED HELP" | SV.P ROMO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-10-2008 11:13 AM |
"a disk error occurred (-48)" | barefoot1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-17-2008 10:40 AM |
"a disk error occurred (-48)" | barefoot1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2008 07:01 AM |
DSI error occurred:-1122 | BOP2NITE | Pro Tools TDM Systems (Mac) | 4 | 04-17-2006 11:21 PM |
an error of type 2 occurred... | DigitalWaveform | Pro Tools TDM Systems (Mac) | 1 | 09-23-2003 09:22 PM |
