Old 07-27-2010, 10:25 AM
David Topple David Topple is offline
Default How to 'warm up' an oud?
I'm editing a track today that includes an Arabic instrument called an oud. Unfortunately it was DI'd. (No, I'm not sure how that happened either!) It sounds thin and quite harsh and it needs some 'warming up'. I wish a professional capacitor mic had been used on it as well, but it wasn't. I've done what I can with EQ, but that's only a partial solution.
I don't have a reel to reel tape machine or an old but 'warm' analogue desk. I also don't have any 'analogue tape' plug-ins or a 'vintage warmer' type plug-in (I have the standard 003 Factory set-up in fact). Re-amping isn't an option either (I'm in a 'home studio' which used to be a living room), and there's also nothing here with a valve in it. There's not even an external pre-amp I could try (I've only got my 003R+ inputs).
Can anyone suggest how I could easily and quickly get this instrument to sound better? Thanks!
Old 07-27-2010, 10:35 AM
nedorama nedorama is offline
Default Re: How to 'warm up' an oud?
Try Sansamp or a similar guitar plugin, but no distortion. Instead, the filters will help roll off some of the harshness.
I would think EQ3 with some of the acoustic guitar presets may also be a good starting point.
Regards,
Ned
Monkey Boy Studios
2013 15" MBP, 16GB, 512GB SSD; OSX 10.15.4; 1.5TB FW800 External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2020.3
Plugins, Virtual Instruments, and real ones
Old 07-27-2010, 02:54 PM
The Dougfather The Dougfather is offline
If you need to add some beef then the Sonnox Inflator is a good plug. Apparently is uses parallel compressions so you possibly look at this technique to help if the plugin wasn't an option.
The inflator also has a curve parameter which also helps the signal sway more towards bass or treble which would possibly help in reducing the harshness.
Good luck!
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Getting warm under the old collar L-Dogg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-24-2010 07:53 PM
should it warm up first MR808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-30-2003 01:53 PM
EQ...Help...Looking For Warm Affordable EQ YOUNGMOESES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-29-2003 12:00 AM
BEST DI FOR WARM FAT SYNTHS SOURCEFOR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-09-2002 12:26 AM
Warm, yet punchy siduri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-24-2000 03:15 AM
