TL space overload
This was a new one for me:
I had session with three TL space instances (along with another three 3rd party reverbs and a bunch of other stuff). And this one single instance of TL space goes into RTAS overload and brings the whole session to a halt. It took me a while to figure it out and isolate the one plug that was causing this, but once I did, I repeated the overload many times. Even with every other track in the session deactivated, this instance of TL space overloaded the RTAS engine. It always happened at the same spot in the tune, when the input to the plug was going into silence. So, it looks like a denormalization error. Except that it wasn't happening to the other two TL space plugs, which had plenty of silence going into them. The one difference on the offending TL Space was that I had made a number of adjustments to the patch. It was a short room impulse, but I shortened it quite a bit more, added 30ms of predelay, and changed the high frequency setting; So, I guess this would add up to more processing demand. And I wonder if that made the problem worse. Anyway, I went back to the stock IR with no adjustments and the problem went away. Things that make you go hmm... (I'm running PT 8.0.1 on WinXPsp3 on an Intel quad) |
Re: TL space overload
last night i had same problem - i try used old method by plug in dither before tl space - and solved
I agree it sounds like a textbook case of Denormalization. Add a dither plug in before TL Space.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Had the same problem, and yes, this i s the solution
Rossi
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100 |
Space (AAX/Native) not authorizing Space 11.1 | YYR123 | AAX Plug-ins | 12 | 01-29-2014 01:33 PM |
Space not able to 'see' all the presets that were created with TL Space | ArKay99 | AAX Plug-ins | 12 | 01-29-2014 03:56 AM |
TL-Space Native and TL-Space TDM question | ArKay99 | RTAS & TDM Plug-ins | 3 | 08-04-2013 08:54 PM |
TL Space Native = CPU overload | Eliza | Pro Tools M-Powered (Win) | 5 | 01-21-2009 04:43 AM |
space allocation problems - when there's heaps of space! | cibot | Digidesign Hardware & Software | 2 | 10-18-2002 05:08 PM |
