Old 05-25-2006, 02:18 PM
Styles Bitchly Styles Bitchly is offline
Default \"POP\" at End of Exported Files?
Hey Folks,
I just exported some regions as files (Original session is 24 bit @ 48K WAV) using that feature in the region bin. I'm exporting them as 16 bit, 22K WAV files (for use with a proprietary software system for phone-on-hold), and all of the files have a distinct "POP" at the end. I've done this same procedure numerous times in the past with no problems at all. It's just "suddenly" started happening, and I can't figure out why. Has anyone experienced this before? If so, what was the fix?
Thanks for your help.
Due to budget cuts the light at the end of the tunnel will be turned off until further notice.
http://www.gidakdigital.com
Old 05-25-2006, 08:16 PM
PhattBastard PhattBastard is offline
Default Re: \"POP\" at End of Exported Files?
Can't tell you why but try doing a simple fade at the tail end of the file. Sometime I run into weird anomalies like you described and that has been my work around.
I know this over simplifies the issue but ... it works for me.
Hope this helps.
Phatt and Bastardy
PPQ of MIDI files exported from Pro Tools John_Toolbox MIDI 16 03-03-2011 06:13 AM
Exported Region as files ,different size L and R ? andre tchmil Pro Tools TDM Systems (Mac) 0 01-29-2007 12:07 PM
QT7 won't play MIDI-1 files exported by PT7! EricWillhelm MIDI 9 04-12-2006 01:37 PM
Mp3 Exported Files terraform 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-06-2002 04:51 AM
Problems with WAV files exported from PT 5.15.1 Siegfried Meier Pro Tools TDM Systems (Mac) 9 03-20-2002 04:14 PM
