Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 07-05-2020, 10:43 AM
Media Man Media Man is offline
Default Pro Tools windows lost off screen
I use dual monitors, and I recently took a Pro Tools session to a friend's studio which only has one monitor.
When opening the session, some of the session Windows were off screen, specifically a third party drum loop program that works as a plug-in.
I could not figure out the Windows 10 command or feature to bring those windows back to the main monitor. Using the Display functions did not show 2 monitors, so switching back to one was not an available option.
I should also mention my Session was created in Pro Tools Ultimate and my friend uses Pro Tools (standard).
I'm guessing this is really simple, but I've been on dual monitors so long I have forgotten.
Any ideas?
Media Man
Pro Tools Ultimate 2020.5
HD Native / 192
Windows 10 Pro
Old 07-05-2020, 02:52 PM
Default Re: Pro Tools windows lost off screen
Any time this has happened to me, the "missing" window is actually not missing, but hiding behind other windows. And when you do find it, its often nothing more than a small title bar sitting in a lower corner. So, if you lost the MIX window but see the EDIT window, hit the command to bring up the MIX window and check the lower corners(sometimes it helps to shrink other windows). As for missing plugins, open any plugin and place it near the upper left of the screen. Then close it and try the plugin that's missing. On my rig, any plugin I open will always open in the same spot of the previous plugin
If none of that works, right-click on the task bar and try the view options(Cascade windows, Show Windows Stacked, etc)
Old 07-06-2020, 10:58 AM
Mertisrules Mertisrules is offline
You could also try changing the monitor resolution
Mac Pro 5,1 2x 3.46 Hex Core Xeon 96 Gb 1333DDR3
OS X 10.14.6 Samsung 970pro 2x 1TB NVME HighPoint 7101a / Open Core 0.7.0 EFI SATA Bay 1
Focusrite REDNET PCIe
Pro Tools 2021.3.1
AMD Radeon RX Vega 64
BM Intensity Pro
Old 07-06-2020, 11:03 AM
JoelG's Avatar
JoelG JoelG is offline
Hover over the Pro Tools icon on your task bar, when the small preivew opens right click on it and select "Move", immediately hold left click and start dragging until you see it in your window.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 07-07-2020, 09:07 AM
I'll give that a try next time it happens, thanks.
Joel
Thanks for the reminder. I'll give it a try.
Flashing black screen on Windows 10 for Pro tools 12 tcbranco Pro Tools 12 0 11-18-2016 04:50 PM
Pro Tools 11 Boot screen for Windows watto Pro Tools 11 0 12-04-2015 09:28 PM
Pro Tools on screen mix windows follow banking . priorytools Artist Series 0 02-21-2015 10:13 AM
Pro tools se blue screen on windows 7 maxhb Pro Tools SE and Essential (Win) 0 07-16-2012 06:55 AM
Please HELP! Grey Screen - Lost song, Lost Soul... deeegenerate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-12-2010 07:05 PM
