Old 01-03-2013, 10:18 AM
Dave12 Dave12 is offline
Default Pro Tools will not Install - How do You Download Windows XP Updates from Avid
I actually have Pro Tools 8 I believe. I have Windows XP, and am getting error messages when trying to install the Pro Tools 8. I was told I need to download some Win XP updates from the Avid webiste, but I cannot see where they would be located after going to the site. Thank you.
Also...Anyone know how to tell which Pro Tools Version you have BEFORE you have installed it. The install disc itself only has this number, 'Version 061510', it does not say if it is Pro Toolls 8, 9 or 10. I bought the M-Audio box and this software came with it, in about January 2012.
Thank you!
Dave
Old 01-03-2013, 10:43 AM
TOM@METRO's Avatar
Default Re: Pro Tools will not Install - How do You Download Windows XP Updates from Avid
The exact error message please.
Are your Windows updates up to date?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-03-2013, 12:07 PM
feliponk's Avatar
feliponk feliponk is offline
Hi: on the Windows side, usually XP SP3 and all the hotfixes for ProTools 8.0.5.
Review this...
http://avid.force.com/pkb/articles/e...n&DocType=1078
Cheers!
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 01-03-2013, 12:57 PM
Review this...
Cheers!
and SP3 would be downloaded from Microsoft(not Avid).
Old 01-03-2013, 04:37 PM
sunburst79 sunburst79 is offline
Thank you!
Dave
My installer disks clearly indicate which version of Pro Tools they are. Not sure why yours would be any different. Earlier versions from 7.0 to 8.0 were color coded. Maroon for MAudio, Brownish black for PTLE and blue for PTHD. However the disks were still clearly marked. PT9 and and newer had purple AVID packaging. Also the installers clearly state which version of PT its installing. So there really shouldn't be any confusion as to which version your installing. If you purchased the unit used and the software came on home burned DVDs than it may not say what version it is. Regardless the actual installer should state its PT version when you run it. The Version 061510 ID isn't ringing a bell.
Make sure your machine is up to date at Microsoft Update. You want to check for the optional MS updates also since you might be behind on a framework like .NET. Any MS components PT needs it should install if they are missing. An example here would be PTLE 8.0 installing a couple of Visual Studio patches while installing Pro Tools. Knowing the exact error would help immensely.
Note: I googled "061510" and came with a Post for Pro Tools SE over at the new MAudio Forum. From the post its not clear whether 061510 is referring to the version number or part number on the interface. I'm assuming its printed on the disk?
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-03-2013, 08:57 PM
The Weed's Avatar
The Weed The Weed is offline
If he bought an M-Audio box, then he should have/needs M-Powered, not Pro Tools LE.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-03-2013, 11:07 PM
Cheers,
True but the installer would still install the Visual Studio 2005 components as needed. These used to show up in the add and remove programs menu as MS 2005 redistributable components. I forget the exact verbage. My point being if windows is up to date the installer should install any needed components.
Earlier versions would some times throw a error message about missing windows components that was referencing the old Windows Media Encoder program. For whatever reason it would do this on a second install or repair install rarely the original install.
It's also very possible he saying Windows Updates when he means Pro Tools updates.
Scott
Core 2 Specs Page
Can't (re) download Pro Tools 8 on my account after a clean install of windows Tony1965 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-07-2011 01:13 PM
Buying 003+ today - Install from DVD or download from AVID? Undertones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-22-2010 12:25 AM
Install Windows Updates first or Pro Tools? DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 45 02-25-2010 11:47 PM
Windows updates required for 6.9 upgrade install? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-10-2005 09:13 PM
which windows updates should I not install? jdolan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-30-2004 03:02 PM
