UI freeze every minute.
Hi.
I'm having a peculiar issue. This has been going on since upgrading to a new system 3 months ago. It's not a show stopper by any stretch, but I'd love to put it to rest as it is an annoyance. Hopefully someone here has experienced this and figured out what the heck is causing it. Essentially, I get a UI freeze every minute, on the minute. All day long, like clockwork, the UI freezes for about a second and then everything will run fine for 59 seconds... then hiccup. Meters freeze, scrolling freezes, timecode display freezes, etc. Playback does not, sync is never lost, etc. In fact, in every other capacity, it is by far the most stable PT experience I've ever had in 16 years. It seems to be only related to graphics. I'm sure there's some sort of polling thing going on with my system, but I am having the darnedest time tracking it down. Any ideas? Perhaps there is a way to determine what the system is doing that would cause this? I've watched Activity monitor very carefully for hours but it does not reveal a source. Mac OSX 10.6.6 Westmere 6core 3.33Ghz 16Gb RAM/OWC SSDs PTHD 9.0.0 HD3, dual 192s. All current plugs, no RTAS instruments (other than the Digi stock) Bluetooth is off, Wifi is off, all Digi recommended optimizations are off... no spotlight indexing, no timemachine, etc. Totally clean system. Thanks, Jamey |
Re: UI freeze every minute.
Could this be an issue with auto save?
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
it goes much much deeper than looking at the activity monitor
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Jamey: Great rig. Congratulations. Are there any network drives mounted? Especially iDisks. I've seen similar behavior with mounted iDisks.
Hi reichman.
Yes, it definitely has something to do with the network, though I'm not sure if it's iDisk related. If I sign out of mobileme, it still happens, but if I disconnect the ethernet cable, it stops. I wish I could figure out exactly what is causing this because I cannot run my systems without being on the network. |
Have you tried removing your network interface from the list in the Network system preference pane and creating a new one? I once cured a similar problem that way. Also, MacPro's have two ethernet ports. Does This behaviour happen in both of them?
You could install a network-monitoring utility, such as LittleSnitch (http://www.obdev.at/products/littlesnitch/index.html) to find the cause of the problem. It will alert you whenever there is traffic on your ethernet port, tell you what application it comes from, where it's going and let you block it or allow it. That could help identify exactly where the problem is coming from. The problem is, once you've found the culprit, the app becomes a nuisance and is a pain in the @$$ to uninstall completely. On my scales, that still weighs less than the GUI freezing every minute. IHTH |
Drenkom,
Thank you. Deleting my network setting and recreating with a manual IP address resolved the issue. Very grateful that you took the time to post that. Thank you. Thank you!!! -Jamey |
-tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
Pro Tools 10 HD (Cursor Freeze/Playback Freeze) | vinlance | Pro Tools 10 | 1 | 07-13-2013 11:40 AM |
One minute I have space, the next minute I don't | newtonab | Pro Tools M-Powered (Win) | 3 | 01-03-2009 05:38 PM |
5 minute freeze | Texas Studio C | Pro Tools TDM Systems (Mac) | 7 | 07-21-2006 11:39 AM |
5 minute freeze | Texas Studio C | Pro Tools TDM Systems (Mac) | 2 | 07-16-2006 01:53 PM |
Why Is a 4 Minute song Bouncing as a 6 Minute Song | rockwithrespect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-31-2004 02:37 PM |
