LE MIDI Problems
I can't seem to be able to play any plugin instruments with either of my MIDI keyboards even though both keyboards show up on the MIDI input list and I can see MIDI data being recorded to a track. There is just no sounds comming out from the Instrument. I have tried using Sample Tank 2 and Battery 2 and I have this problem with both of them. Any suggestions?
Re: LE MIDI Problems
Hi n3xus
Check MIDI Thru and check that the Audio Input on the Instrument track, if using a Instrument track, is assign to a valid Input. filosofem
Aaron Mulqueen - 001 HD Native |
Thank you, checking the MIDI thru worked. Why did that make it work?
When MIDI Thru is not enabled, Pro Tools' can not communicate with the Controller, nor the MIDI Device, enabling this, results in communication with Controller and Device.
filosofem
Midi Studio Setup problems & Plugin problems | J Nauti | MIDI | 0 | 03-02-2010 11:04 AM |
Problems with Midi sound / Midi Controller | joe_04_04 | MIDI | 2 | 07-16-2009 12:43 PM |
MIDI Problems with Axiom 25 MIDI Controller | jasonguitar | Pro Tools M-Powered (Win) | 12 | 04-03-2007 10:04 AM |
Help...Problems with midi | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-27-2004 06:35 PM |
MIDI NOTES DISSAPEAR!!?? WIERD MIDI PROBLEMS | ManhtnProjct | Pro Tools TDM Systems (Mac) | 2 | 10-29-2001 08:39 PM |
