Re: PT 12.7.1 crash
Thank you for your input. I do appreciate it. |
PT 12.7.1 crash
Do you have disk cache enabled?
Check the console logs for system errors or warnings (Console.app) Verify the file system using the disk utility (luckily we have a much more robust file system than HFS+ coming soon....). Do a Terminal find command for every file newer than the date of the few files you do have and let it scan all drives (e.g. specify / as the starting directory). Just see if it turns up anything. type "man find" into the terminal to see how to use it, or ask here if stuck. I would be careful trusting that disk or the session file for future work. Sent from my iPhone using Tapatalk |
Re: PT 12.7.1 crash
It happened to me 3x. Over months. It is because the physical drive is about to go. There is bad sectors on the drive platter that is being written onto. Unless you are using ssd recording drive then it s not exact. It happens to me using FireWire spinning drives. Long time ago. Sent from my SM-G955U using Tapatalk |
Re: PT 12.7.1 crash
Re: PT 12.7.1 crash
Interesting. I don't know exactly what I'm looking at but the console log has activity every few minutes. It looks like 4 minute intervals. Sometimes its more active with more logs. There is no log activity after 10:34 AM until 2:05 PM when I shut PT down. Then 3:47 PM I see what must be my attempt to boot PT, 3:50 my force quit, and then at 3:53 PM my successful boot and then log activity continues at a rapid pace up to the current time.
Crazy? |
Re: PT 12.7.1 crash
What log file is that in?
Re: PT 12.7.1 crash
Thanks for the tip. I'll keep you posted. Scott |
Re: PT 12.7.1 crash
Scott |
Re: PT 12.7.1 crash
Thanks for your input, Scott |
Re: PT 12.7.1 crash
The console log. The All Messages section.
Pro Tools 11 Crash Reporter - send in those crash logs! | Bob Brown | Pro Tools 11 | 37 | 01-29-2015 12:37 PM |
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng | FuneralMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 11-16-2009 12:02 AM |
Crash Crash Crash Live 6 Pro Tools Rewire | TimmyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2007 11:26 AM |
Crash, Crash, Crash!! 7.2 when deleting breakpiont | Mark 66 | Pro Tools TDM Systems (Mac) | 2 | 01-28-2007 09:13 PM |
Installed 32track le version, won't run with Reaktor crash crash crash | Christian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2002 11:05 AM |
