recording in stereo
Hi, i don't know how to record in stereo. My track is in stereo but as it goes in the sound card in 1, it's on the left and if it's in 2 it's on the right. I didn't have this problem before, it used to work in 1 and record in 1 and 2. Do you know what to do to solve this problem? I work on pro tools 10 with a scarlett 2i4. Thank you. Diego
Re: recording in stereo
It’s pretty hard to get a clear understanding of what you’re describing but I’m gonna take a stab at it.
Perhaps in the past you were creating a stereo track and so input 1&2 were what you as being fed to that track. Now t sounds like you may have a mono track so you’re only getting input 1. Sent from my iPhone using Tapatalk |
Or you might be committing a common newbie goof by thinking you must have a stereo track for everything. What is the source(what are you recording)? If its a vocal or maybe an acoustic guitar, those are mono sources and should be recorded to a mono track(using a single input). Once that gets recorded, then you can pan within the stereo field So much to learn, so little time
Hi, I'm working with my electric guitar on Altitude from Jason Becker with a backing track. I thought it was better for the result to record in stereo. The problem is that I can only have input 1&2 selected in the track and before I could work on input 1. |
The problem is that most guitars are mono, its like recording a vocal, people has only one mouth. You have to record in a mono track. Unless you have a guitar that has 2 outputs there's no other way around. On the mono track you can then insert stereo effects like reverb and delay to make it stereo, if you use inserts that say mono/stereo then the mono track is converted into stereo even though it will still have a mono input and information.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Its actually quite simple; A source that has a single output goes to a mono track. A source with left and right outputs goes to a stereo track. The last wildcard is a source that uses 2 mics, but is not a stereo source(like a guitar cabinet with both a ribbon mic and a dynamic mic). That should be recorded to a pair of mono tracks(so you can treat each separately).
In the spirit of teaching, recording a mono source to both sides of a stereo track does not make a stereo recording. It makes a dual-mono recording as left and right are actually the exact same signal.
Need some help recording in stereo. | DomcSore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-11-2009 09:14 AM |
Recording stereo | Tim P | Pro Tools M-Powered (Win) | 12 | 05-18-2006 09:52 AM |
Recording in Stereo | jvanslyke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 03-24-2004 08:05 AM |
001 and stereo recording | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-26-2003 10:29 AM |
Stereo Recording | Hermes | Digidesign Hardware & Software | 3 | 05-18-2002 01:07 AM |
