Old 03-07-2017, 12:24 PM
reflixtinian reflixtinian is offline
Default Antelope Orion Studio Thunderbolt Problem 12.7
I'm having this problem, along with other fellows
I'm running PT12.7 , (same happened with 12.6)
Mac Pro late 2012 , Mac OS Sierra.
The problem happens when switching between pro tools sessions recorded at different sample rates, Let's say I open a 48K session, I close it and open a 44,100 HZ one, the clock won't update automatically...(on the Orion)
That can cause to record (accidentally) 48.000khz audio in a 44.100khz session etc etc. You won't notice any audio problem until the clock updates tho the correct sampling rate.
Other DAWS like logic and cubase make Orion's clock update.I don't see why pro tools doesn't.
Any similar experience or solution?
(last page)
https://www.gearslutz.com/board/prod...l#post12487712
Old 03-07-2017, 05:59 PM
climber climber is offline
Default Re: Antelope Orion Studio Thunderbolt Problem 12.7
I've also seen this in PT 7. I've taken to leaving the Orion CP open all the time so I can change the session SR quickly. I can always immediately tell if the SR is off so it's just an inconvenience. that said I'm pretty certain that this was working prior to 12.7.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 03-08-2017, 08:24 AM
I also leave Orion Studio's control panel open all the time, and I turn the unit off from the control panel as well, I hope Avid reads this, by the way I had the same problem with pro tools 12.6 I'm now using 12.7.
Old 03-08-2017, 10:10 AM
The Weed's Avatar
The Weed The Weed is offline
Some 3rd party interface drivers will allow Pro Tools to change the Sample Rate, others won't. I have an RME UFX and I have no issues changing the Sample Rate from within Pro Tools, however, I can't change the Buffer Size. Being that I can change the Sample Rate and you and others with a different 3rd party interface can't, would seem to indicate that it's up to the 3rd party interface's drivers to allow this, not Avid.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Antelope Orion wwittman Pro Tools 12 17 02-28-2019 05:31 AM
Antelope Orion and Dangerous Source issues. joeboisits Pro Tools 10 3 05-26-2015 02:34 PM
Pro Tools 9 latency with Antelope Orion 32 mkosacek Pro Tools 9 3 09-05-2013 07:13 PM
Antelope ORION, BURL B2 ADC, SSL MX 4-16, Focal CMS-50, Focal CMS SUB Imagine Buy & Sell 14 05-09-2013 01:42 PM
Antelope Orion - any users? Actionmusic macOS 0 02-24-2013 03:49 PM
