Old 11-01-2016, 08:40 AM
DJ Hellfire DJ Hellfire is offline
Default Thoughts on the Eiosis e2deesser?
How do you guys feel about the Eiosis e2deesser. Been trying it on a few things and Pro Tools Expert has a good video on it, but I still have mixed feelings about it. Maybe I just need to use it a little more. Some times it feels a bit heavy handed, other times not enough. I've been having a tough time finding a middle ground and as a result keep going back to the Waves Deesser.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 11-01-2016, 09:05 AM
YYR123's Avatar
YYR123 YYR123 is offline
I am also interested, i have yet to find a DS'r that actually works w/o making me hate it.
I do and have used MB compression more often than not.
The best version I've heard in my most humble experience was the HOFA IQEQ ----dynamic equalizer is I believe what they call it. My Plugin Alliance version works pretty well too.
Daniel
Old 11-01-2016, 09:07 AM
dtmprod dtmprod is offline
Default Re: Thoughts on the Eiosis e2deesser?
I love it, don't use anything else anymore. It can be a bit confusing at first to setup, so I asked someone from Eiosis for best workflow. I'll paste his response below. I find that most de-essers tends to dull the top end as you hit it harder. This is the only one that will actually make it sound 'cleaner', especially if you use a bit of the saturation knob.
What I do personally is to first adjust the Sensitivity until it's getting the exact amount of sibilance. I preview it using the monitor controls under the EQ to ensure I've got all of the sibilants. Then, I will dial in a desired EQ curve, mainly taking out high end with a shelf and deciding if I need any other EQ bands. Then I'll adjust the Amount knob to decide how much of the Sibilant EQ attenuation I want. Then I'll turn up the Auto, then the Smooth knob to taste. I get great results this way.
Hopefully that helps.
Old 11-01-2016, 11:12 AM
Meads Meads is offline
I myself have been looking for the perfect deesser and haven't found it yet (own most of the ones available). I use several different deessers in a row, which to me yields the best result.
The Eiosis DeEsser doesn't appeal to me at all. It alters the sound of the signal too much.
The ones I find to work best in conjunction are Fabfilter, Waves Ren and SPL.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-01-2016, 11:34 AM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by YYR123 View Post
I have yet to find a DS'r that actually works w/o making me hate it.
I have. It's called volume automation
Janne
Old 11-01-2016, 11:41 AM
YYR123's Avatar
SSSSSSSSSSSSS sneaky guy.....
Daniel
Old 11-01-2016, 11:54 AM
treason treason is offline
I use a similar approach incorporating Fabfilter Pro DS, Sonnox Supresser and McDSP AE400/AE600.
I'm over anything Slate related, and while I realize Eiosis is not Slate, they share the same algorithms architect. I've incorporated a policy to divest the studio of as much Slate related products as possible. So it also does not appeal to me.
YMMV, etc ...
T-
Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
Old 11-01-2016, 02:08 PM
WernerF WernerF is offline
I second the idea of volume automation. I have pretty much all of the de-essers and some of them work ok but nothing really works as well as good old volume automation or, even preferably, clip gain manipulation. Works like a charm but obviously takes longer than using a plugin.
Old 11-01-2016, 10:40 PM
deanrichard deanrichard is offline
While I don't have the Eiosis, I have gotten good results using the TDR Nova dynamic EQ as a deesser. It's free, and excellent, so if you don't already have it you might want to use it to compare.
Old 11-01-2016, 10:43 PM
I also manually set clip levels when sibilance is a major problem. It doesn't really take all that long, I can do a vocal track in a few minutes. But as you said, it's not as quick as adding a plugin.
HTML code is On
FS: Slate, Eiosis, Nugen, BX skipdog Buy & Sell 0 08-18-2016 04:23 PM
Eiosis AirEq Premium michad Buy & Sell 2 08-31-2015 12:18 AM
Eiosis AirEQ…. thoughts? Rosco1969 AAX Plug-ins 10 11-19-2014 12:39 PM
Help with Eiosis ESL Vocoder micpool Pro Tools 9 0 02-25-2011 07:27 AM
Eiosis Air EQ TDM doesn't display as TDM mgoorevich Pro Tools TDM Systems (Mac) 5 03-10-2010 11:15 PM
