"Tape" speed
I've been asked to archive reel-to-reel tapes originally recorded in the mid 60s. I'd like to use my 001 and Pro Tools LE to give them a good digital cleaning.
Problem is, many of the tapes were recorded at 3 3/4 speed. Is there anyway I can achieve 3 3/4 speed playback from within Pro Tools LE? |
Re: "Tape" speed
Speed has nothing to do w/pt
you need to play them at 3/, 3/4 ips on a reel to reel new one probably won't go that slow, find an old one |
Re: "Tape" speed
That said, I don't think a 3 3/4 ips reel-to-reel deck has been manufactured in the last X amount of years, which is why I posted my question here. There must be some way to achieve the desired playback spped digitally. |
Re: "Tape" speed
So let me get his straight,
your going to thread your magnetic tape into pro tools, without a reel to reel? [img]images/icons/confused.gif[/img] This I gotta see [img]images/icons/wink.gif[/img] |
Re: "Tape" speed
If you're asking if you can play the 3 3/4 ips tapes on a faster playback deck and then correct the pitch in PT, the answer is "yes." You could digitally slow the tapes back to proper pitch. The problem is that with that extreme a speed correction, there would be an extreme amount of digital artifacts, and the quality of the recording after digital processing would be horrendous. So while it is possible, it's not practical.
Re: "Tape" speed
If I understand you correctly, you are hoping that there is some plugin in PT that will allow you to dump the tracks in at the speed your deck is and then slow them down? There are plugs like Serato's Pitch'n Time, and Digi has their own plug for doing this but I'm not sure you would be happy with the end result as the file goes through some radical changes to get there. Pitch'n Time will sound better than the Digi plug, but still...
Re: "Tape" speed
Condescension aside, I CLEARLY would like to DUB a reel-to-reel tape, recorded at 3 3/4 speed from a reel-to-reel deck running at 7.5 ips in to Pro Tools LE. At that stage, I would like to find a way to DIGITALLY playback the audio at the ORIGINALLY RECORDED 3 3/4 speed as I don't have access to a reel-to-reel which plays back audio at 3 3/4 speed. Now how do I thread this tape through the XLR....? |
Re: "Tape" speed
You might wanna try the "Speed" plugin by wave mechanics, it's quite amazing and the simplest
Hope it helps Joel |
Re: "Tape" speed
was trying to be funny ,not condecending,My apologies.
[img]images/icons/smile.gif[/img] You could probably find an old crappy one w/3/3/4 ips for less than some restoration plug's,and you wouldn't have any digital speed manipulation artifact's. That slow of speed is going to be lo- lo- lo- fi, no matter what you do,IMO. My old tube reel to reel's are some of my favorite pieces(not for pulling tape) I use them as quitar pre/amp, tube pre in recording chain,tube power(alot of old one's are powered [img]images/icons/tongue.gif[/img] )But you should try the double speed recording in pt and see if it's tolerable |
Re: "Tape" speed
I just checked the manual,
there is half speed recording(shift+spacebar) Not double speed recording but what about this(I need a light bulb graemlin [img]images/icons/rolleyes.gif[/img] ) bring in to pt(it's 2x's fast) play at half (shift+spacebar) record to stand alone recorder, huh [img]images/icons/smile.gif[/img] |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Old School Studio "work" flow chart from Tape Op's facebook page | Craig F | General Discussion | 0 | 01-08-2013 07:21 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
Best Plug-Ins for Exciters/Tape Saturation/"Color" | royceg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-10-2009 08:29 PM |
"Slowing down the tape speed" | bsmith23 | Tips & Tricks | 6 | 05-11-2009 07:03 PM |
