Old 02-09-2015, 08:02 AM
kittybite kittybite is offline
Default Eleven Rack Problem
My Eleven Rack is on.All looks good.Programs change with my midi pedal board.Parameters work.Everything looks fine.All set to the right inputs and outputs however there is one problem.
I have to switch the unit on and off at least 25 times until i get a signal.
I dont obviously turn on my power amp until i get a signal.
I even plug the headphones in to eventually hear sound after switching the unit off and on around 25 times.
I have reset memory,also done a hard reset and all things possible.
USB is unplugged.
Any solution would be much appreciated.
Old 02-09-2015, 10:25 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Eleven Rack Problem
Could be hardware related. Since both the main and headphone outputs seems to have no signal, maybe it is something with the input. Have you tried moving around the input cable to see if the sound cuts in and out? Maybe try the mic input. Also, if you are in PT, do you see signal on the meters?
Will
System Details
Eleven Rack problem The Good Answer Eleven Rack 5 06-04-2014 10:33 AM
eleven rack - problem hydra Eleven Rack 2 10-05-2012 01:12 PM
Eleven Rack Problem adflaker Windows 3 11-09-2011 02:27 PM
Eleven Rack/003 set up problem? Ph.D Eleven Rack 3 02-15-2011 03:13 AM
Eleven Rack Problem Päng 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2010 12:54 AM
