  #91
Old 07-16-2012, 10:52 AM
Wolfgang Eller Wolfgang Eller is offline
Default Re: PT10 Language
Please vote:
http://protools.ideascale.com/a/dtd/...age/85683-3779
www.srs-mastering.de
Mac Pro 6.1-8core, OS 10.13, PT2018, HDX2, Sonnet Echo Express III-R, Madi Interface.
  #92
Old 07-20-2012, 10:08 AM
Push
  #93
Old 08-02-2012, 05:21 AM
Felix Rost Felix Rost is offline
bump
  #94
Old 08-05-2012, 05:33 AM
clausiii's Avatar
clausiii clausiii is offline
Default
My favourite is "Schlag identifizieren"! Now that's pure nonsense!!!
(Bump)
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #95
Old 08-16-2012, 12:32 PM
Today I did a test setup on a second startup disk with 10.7.4:
I started PT 10.2 with the AVID script and guess what - german keyboard layout is preserved in text entries, just like it should be! Hooray!
So I have to go on from 10.6.8. Too bad I don't like all those useless GUI changes in Lion.
Last edited by Felix Rost; 08-18-2012 at 01:57 PM. Reason: 10.7.4 is of course Lion, not Mountain Lion..
  #96
Old 10-18-2012, 08:28 AM
10.3.2 and still no language selector.
  #97
Old 10-18-2012, 02:43 PM
clausiii's Avatar
Default
I don't think that it's a main issue for Avid. I hope they implement selectable language support in PT11.
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #98
Old 10-18-2012, 04:01 PM
Meads's Avatar
Meads Meads is offline
It doesn't even bother me anymore. I've been getting used to using the script. Doesn't make any difference if I hit the ProTools-icon or the script-icon to launch. (But I'm still thinking that it's been a stupid idea on Avid's part to begin with.)
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24
  #99
Old 10-15-2013, 05:25 AM
kD2's Avatar
kD2 kD2 is offline
hi, i'm new to this comunity and a fresh pro tools 10/11 owner. i need my tools to be in english. having os x in german and pro tools in english is nice, but german as the language of my os is no priority. the scripot does not work for me, nor does changing the system language, pro tools is still in german. im running 10.6.8... avid pleas, it can't be so hard to implement a choice option or a workaround that does the trick...
tURN iT uP!... a lITTLE lOUDER!
  #100
Old 06-09-2014, 10:54 AM
hugocentrique hugocentrique is offline
Hello,
I don't know if Avid changed this in PT11, but I have found a nicer workaround for PT10. It involves creating a shell script file inside the Pro Tools.app package, which we run instead of the actual Pro Tools application. The shell script then runs the application with the command-line argument AppleLanguages '(en)', hence running it in English as default. Here's how to do it:
If PT is running, quit it!
1. Command-Click the PT icon in the Dock.
2. Select the PT application and hit Command-D. This will make a backup of the app, in case you mess things up. You can delete the copy once you have confirmed everything works.
3. Right-Click the PT application and click "Show Package Contents". Navigate to Contents/ and open Info.plist (you might have to right-click and select Open With... you can open it with any plain text editor). Look for the entry CFBundleExecutable and change it to parameterized-app.sh (between the <string> and </string>)
4. open Terminal and enter the following:
touch /Applications/Avid/Pro\ Tools/Pro\ Tools.app/Contents/MacOS/parameterized-app.sh
open /Applications/Avid/Pro\ Tools/Pro\ Tools.app/Contents/MacOS/parameterized-app.sh
A text editor will open. Copy these lines in the file:
#!/usr/bin/env bash
exec /Applications/Avid/Pro\ Tools/Pro\ Tools.app/Contents/MacOS/Pro\ Tools -AppleLanguages '(en)'
Save and close.
5. In Terminal, enter:
chmod +x /Applications/Avid/Pro\ Tools/Pro\ Tools.app/Contents/MacOS/parameterized-app.sh
6. Quit Terminal, and move the PT application to a different folder, and back again. This step is essential, otherwise it won't work. I had to hit command while dragging the app, otherwise it makes an alias instead.
Now your PT application should always run in English without further manipulation. However, any update to Pro Tools will revert these changes. I guess a script could be made to automate these steps!
Last edited by hugocentrique; 06-09-2014 at 10:55 AM. Reason: Boldening important information
Language chek0 Pro Tools Express on Mac OS X 0 12-06-2012 08:55 PM
How do I change language? wezcountry Windows 1 07-11-2011 02:42 AM
multiple language GUI dalaware Pro Tools M-Powered (Win) 0 08-07-2010 12:47 AM
GUI language switch OS X Kid_Beluski Pro Tools SE and Essential (Mac) 0 05-25-2010 12:04 AM
About foreign language Laverne General Discussion 0 03-27-2007 08:37 PM
