Old 02-11-2019, 04:46 PM
slollar slollar is offline
Default Pro Tools First 2018.7 Xpand!2 Presets Missing
I have Windows 10 64-bit and Pro Tools First 2018.7.
When I open the Xpand!2 view I do not see any presets loaded; it just says "<factory default>". I am able to select individual components but not any presets. I have uninstalled ProTools and reinstalled twice with the same results. I also tried running XPand!2 setup.exe but nothing changed.
From what I understand, XPand!2 should be installed (not a separate installer) when I install this version of Pro Tools First.
My .big file is installed here: C:\Program Files\AIR Music Technology\XPand2
My .ptxp files are installed here: C:\Users\steph\Documents\Pro Tools\Track Presets\Avid\AIR Instruments Bundle\XPand!2
I tried opening a case which was promptly closed since I do not have support . Please help! My head hurts from banging it on my desk.
Old 03-01-2019, 06:50 PM
Default Re: Pro Tools First 2018.7 Xpand!2 Presets Missing
Nobody??
Old 03-02-2019, 04:30 AM
xrekcor's Avatar
xrekcor xrekcor is offline
Originally Posted by slollar View Post
Nobody??
Xpanda2 is listed as a seperate install, for Windows it’s a 1.23Gb file by itself. You should be able to get it from your product page.
Have you tried “Import Setting” (in the third image) and manually locate and load the preset file?
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 03-04-2019, 05:23 PM
Thank you for replying.
Xpand!2 is supposed to be included in the PT First install. There is not a separate install in my products page. Application manager shows it as being installed.
I tried clicking 'import settings' but i'm not sure where the files should be. Do you know where the preset files should be located?
Old 03-04-2019, 09:21 PM
xrekcor's Avatar
I guess it must be different for PT First. Is that the free version?
Rob
Old 03-05-2019, 02:43 AM
xrekcor's Avatar
With PT First being free you will prolly be last in line for support if any.
I’ve had a look and yup you should have it. That .ptxp file should be the one..... have you tried reloading it? I’m on a Mac so I can’t compare the file location with you being on a Win.
Also you might find your version of Xpanda2 is a very stripped down version. xpanda by itself is US$99 so maybe you don’t get things like presets per say but have to create your own.
Rob
Old 03-05-2019, 06:42 AM
Yes it's the free version. I bought a Scarlett recording device and it came bundled with it.
Old 03-05-2019, 10:13 AM
K Roche's Avatar
K Roche K Roche is online now
Yes the presets are not in that default tab or the "Preset tab at the top, that is for saving and naming user defined presets.... If you have not already found them they are accessed in the 4 dark rectangular synth channel windows on the left side of the GUI ( in the upper right of that rectangle) there is a little down arrow, click that and a dropdown with presets will open
System :
Enjoy the Journey
.... Kev...
Old 03-06-2019, 07:23 AM
I thought there should be a list in the box that says "factory defaults", like the screenshot I've attached, that contains drum presets in each of those 4 blocks for different styles of music.
Old 03-06-2019, 10:43 AM
K Roche's Avatar
opps you are correct I was thinking about the "Presets" button at the very top
So yes You should have not only the instrument category list but the actual patches as well
System :
Enjoy the Journey
.... Kev...
Presets missing from Xpand!2 [email protected] Virtual Instruments 9 05-25-2019 01:20 AM
Xpand 2 - missing presets? TLK Tom Virtual Instruments 10 03-29-2019 09:49 AM
PT 2018 Xpand2! Missing presets and disappearing MIDI input Harleyman Windows 1 03-17-2019 02:30 AM
Pro Tools First 2018.1 Missing EQ Graph panel Jakeman Pro Tools | Intro Discussion 5 02-06-2018 08:00 PM
