Old 02-08-2015, 10:35 AM
ergalthema ergalthema is offline
Default Re: Pro Tools not recognizing iLok
This issue continues to happen. One port will work one day, then it won't work. I just keep moving the iLok around and it eventually works for a while. This is absurd.
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory.
Old 06-11-2015, 11:30 PM
theoldmusicman theoldmusicman is offline
I just purchased PT12 this afternoon with a brand new iLok2. So far I have only been able to get PT to see the iLok2 and work twice. Most of the time it doesn't see it even though the iLok License Manger sees it fine. Also noticed that the iLok doesn't show up in Finder either. Not sure if it's suppose to or not but any other USB memory stick I put in shows up. I feel like I've waster a lot of money and a lot of time. Should have stuck with LogicPro X.
Old 06-12-2015, 04:41 AM
Given the total lack of system info but assuming this is the same computer you had Logic on I'm going to play Miss Cleo and say you're running some kind of Mac. The USB port you have the iLok2 plugged in to - is that a USB3 port? If so those have been known to have issues that can be solved by using a USB2 hub to plug into the computer and plugging the iLok2 into that.
You do have the PT12 license asset on the iLok right?
An iLok is NOT a memory stick and will not show in a Finder window.
Jack
QAPLA!
Old 06-18-2015, 10:15 AM
terryrocks terryrocks is offline
When I've had ilok recognition issues, it's been because of a plugin that was part of a packaged download in which I only paid for one of the plugs. The SSL stuff has been buggy like this for me.
Old 06-18-2015, 01:40 PM
Whos SSL plugins are you using? Waves or somebody else's?
Jack
QAPLA!
  #16
Old 06-18-2015, 03:54 PM
Solid State Logic
  #17
Old 06-18-2015, 05:09 PM
Solid State Logic
The Duende plugins then right?
Jack
QAPLA!
  #18
Old 06-18-2015, 06:08 PM
Yes
  #19
Old 01-27-2016, 05:45 AM
OctopusOnFire OctopusOnFire is offline
Started happening to me a couple weeks ago, after using pro tools for over a year. Resetting NVRAM won't help. So far I've been trying to open the ilok license manager, other than the solutions mentioned above. It's pretty random and it kind of works whenever it pleases.
It's quite annoying, especially when you're in the middle of a recording and the musicians are waiting for you. I want to keep using PT but I don't think these things are acceptable for a DAW that is meant to be used in daily work.
I have this problem in a 2015 MBP, with 2.0 and 3.0 usb connections. The problem happens randomly in both of them.
EDIT: Pro Tools also crashes after the issue, it often needs for the whole system to restart.
  #20
Old 01-27-2016, 07:14 AM
JuanPC JuanPC is offline
http://duc.avid.com/showpost.php?p=2276372&postcount=2
http://duc.avid.com/showpost.php?p=2276501&postcount=5
Also happen if you install a license in the PC, not the Ilok USB.
Not recognizing my Ilok patrickj75 General Discussion 2 11-05-2012 02:14 PM
[HELP] Pro Tools not recognizing licenses on Ilok dsdaniels Windows 3 10-27-2011 01:27 PM
SC48 not recognizing iLok vlepore VENUE Live Sound Systems 4 10-03-2010 01:37 PM
BF Tel-Ray Delay 8.0.0 not recognizing iLok auth [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-02-2009 12:45 PM
PT not recognizing license on iLok cueball73 Pro Tools M-Powered (Mac) 4 01-23-2009 09:38 AM
